Question about DeLonghi Perfecta ESAM 5600 Espresso Machine & Coffee Maker
Delonghi perfecta ESAM 5600 no steam - DeLonghi Perfecta ESAM 5600 Espresso Machine & Coffee Maker
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
SOURCE: hello i have an Delonghi esam
I had this problem until I realised that you need to switch the machine off by pressing the on/off button on the front of the machine first *before* switching it off at the back and unplugging it. This moves the infuser unit further to the bottom and then allows you to take it out.
Posted on Nov 11, 2010
  • 4 Answers
SOURCE: DeLonghi Perfecta ESAM5500 when trying to make a
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Posted on Feb 08, 2011
SOURCE: delonghi perfecto esam 5400 instruction manual. I
A small stone got pretty stuck in the grinder of my Delonghi esam 5400. Anyone knows how to remove it?
Posted on Mar 22, 2011
murdozzz
  • 41 Answers
SOURCE: how to replace Delonghi magnifica
ha this is the same problem i had just last week at a customers house with the same machine , the knob does pull off but it is hellish tight and you feel like the valve is about to burst through the front of the machine but it does pull off, when fitting the new knob it is a good idea to put some grease over the shaft before pushing the new knob on as it's nearly as hard pushing the new one back on as taking the old one off.
regards
Ian
Posted on Apr 17, 2011
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi esam 5600 will not froth milk
Here is the manual:
http://www.delonghi.com/Global/InstructionManuals/EN/ESAM5600%20Intro%20EN.pdf
Two causes from the troubleshooting section:
The froth regulator is incorrectly adjusted. • Adjust following the instructions in the section on preparing drinks with milk.
The milk container lid is dirty. • Clean the milkcontainer lidasdescribedin the section "Cleaning the milk container".
Feb 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
"GROUND TOO FINE ADJUST MILL! Insert water spout
  1. Insert steam spout and push OK.
  2. Fill your tank and add descale solution.
  3. Go to program settings - Descale.
  4. Follow the prompts on the readout.
  5. After descale and rise are complete refill your water tank.
  6. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Sep 27, 2013 | DeLonghi Perfecta ESAM 5600 Espresso...
DeLonghi Perfecta ESAM 5600 Espresso Machine & Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
