Question about Kyocera FS-1135MFP
FS-1135MFP getting error 2101 when scaning doqument
Fs_1135mfp_getting_error_3101_when#solution-heading
Posted on Feb 01, 2013
Hi, not an expert by any means, but have set several of these up for scanning. When I get these error codes I usually get it corrected by making sure the workstation has a password for the FS-1135 to use. Here are my steps that usually correct the problem.
1. Make sure the scan Folder is SHARED and PERMISSIONS are set correctly.
2. The Desktop/Workstation needs to have a password for the scanner to use.
If the "User" doesn't want to use a password then I create another user account and name it Scanner and give it a password of Scanner. Then I use that password "Scanner" when setting up the address book on the FS-1135.
I've come to the conclusion that the error code itself doesn't really tell you anything. I've gotten several different error codes, including 1103, that the above has corrected the problem.
Posted on Jun 15, 2015
MEMORY ALLOCATION error is what I have. What could be the problem?
you need additional memory for the fax or scanner for scanning large files.
Mar 17, 2015 | Kyocera FS-1135MFP
Error c6400 in 1135
The Error is described in the Service Manual as - "Zero cross signal error The zero cross signal does not reach the control PWB for specified time."
This can be a damaged wire harness between the High Voltage PCB and another board or a defective Power Source PCB. Bad power at the outlet can also cause this.
Move the machine to another location and make sure nothing else is plugged into the same line. If the problem goes away have an electrician check your wiring.
If the problem still occurs have a Service Technician check the machine and replace the bad part.
Feb 27, 2015 | Kyocera FS-1135MFP w/ Document Feeder
Error Type: Connect
it means you can connect to the smtp server check all the info to make sure its correct
Jun 02, 2014 | Kyocera FS-1135MFP
Scanning Problem FS-1135MFP. Error Type: Connect
check to make sure all your smtp info is correct (server address,authentication ,and auth user and pass)
Jun 02, 2014 | Kyocera FS-1118MFP Laser Printer
Kyocera fs 1135mfp cf000
It's most likely a hard disk error. Try getting the HDD replaced.
Dec 19, 2013 | Kyocera Mita Office Equipment & Supplies
Developer unit not installed
yocera ecosys fs-1124mfp toner container 0r the developer unit is not install
Apr 09, 2012 | Kyocera Office Equipment & Supplies
KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
Oct 14, 2008 | Kyocera Mita FS 3800 Laser Printer
Kyocera FS-1135MFP Logo
810 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
