Question about Philips Televison & Video
Static channels - Philips Televison & Video
  • 1,238 Answers
Please check your connection of cable box
Posted on Jan 12, 2013
Vtech cordless static
The control is usually a sliding switch in the base station, not on the handset. Open the battery holder and look in there,
Dec 20, 2013 | Vtech DECT 6.0 Digital Cordless Phone
I have a Static noise coming from the right channel of my mixer. I hear it coming out the right speaker as well as the right ear of my headphones (jack). How can I fix this?
That sounds like a bad connection but it can also indicate your mixer has a problem. If it occurs on all channels it is the mixer, if only one then the problem is in the input. Check your cables, they are a big culprut in problems like this.
Jan 08, 2013 | Stanton SA-5 DJ Mixer
I have a galaxy 33hml and i can not figure out how to set it up with the nobs i mean can you help me....
first of all is it set up to a antenna source? if so then turn the squelch nob counter clockwise all the way, then turn the device on. next start at channel one and slowly turn the squelch clockwise until the pin moves or you hear static. then surf the channels adjusting the squelch to to that static point until you find your active station. from there to cancel static between transmissions turn the squelch so that it is just below the static marker.
Feb 10, 2011 | Galaxy Radios DX-33HML 40-Channels Base CB...
It is an old speaker (DM601 S2) but well cared for. Have clear sound in one speaker and static in the other.
It sounds like a ground problem with the speaker crossover circuit or the amplifier. Turn the amp off and disconnect one speaker and interchange it with the other using the same speaker wires. If the static speaker is now working interchange the speaker wires and try it again. Or if the same speaker still has static it is the speaker. If the static is on the same channel then you have a bad wire or if both channels work it was a bad connection. If the problem remains on the same channel change the speaker wires. If the problem switched to the other channel then it is a bad speaker wire or connection. If the same speaker has the same problem it is most likely the crossover circuit in the speaker which is used to filter frequencies of the audio signal by using capacitors and coils. If the static speaker is now working and the other speaker is now not working it is the amplifier. If the static problem is on all input devices I would trouble shoot the preamp section of the amplifier.
Jun 23, 2010 | B&W DM602 S2 Speaker
Will not go past channel 21. All I get is static
Are you using a cable? If you do try re-scanning your channel and be sure that you're on the cable mode
May 11, 2010 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Behringer xenyx 802 static in left output
if its only on left channel you have to change the ic output from that channel.
Jul 08, 2009 | Audio Players & Recorders
Static on all cable channels
The tuner is questionable The problem lies inside the isolation box. Ask a repairman to open this isolation box and resolder the small board. There are two small resistors that need resoldered. This also has the rf connector on it. And you may have him resolder the tuner if this does not fix it. Have him inspect any and all grounds on the main board as well. Good Luck
May 31, 2009 | Toshiba CF32F50 TV
When changing channels sporatic static,
Please feed again cable channels in TV by selecting Auto Search / channel preset in TV Menu.
This will update channel data stored in TV memory.
Mar 18, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Please explain the working of this code
It's a Java http server (webserver) that serves random "prices" if they match a search string.
Well here is an explaination:
private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};
These are search strings
private static Random rnd = new Random();
This generates a random number
private static Charset cs = Charset.forName("UTF-8");
This is the charset that the http server uses
ServerSocketChannel server = ServerSocketChannel.open();
Create a new server
server.socket().bind(new InetSocketAddress(8055));
Bind the http server to port 8055
The rest is handling the request and processing it
But here:
if(Arrays.binarySearch(symbols, symbol) >= 0)
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;
else
response = "Price not available";
channel.write(cs.encode("HTTP/1.0 200 OK "));
channel.write(cs.encode("Content-type: text/plain "));
channel.write(cs.encode(response));
channel.close();
It sees if the string input matchs: DELL INTC MSFT ORCL SUNW.
(private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};)
If so, it gives a price based on a random number.
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;)
Or else
It says "price not available"
then it gives a html header to end the error message.
Hope I helped you :)
Gook luck
Nov 26, 2008 | Computers & Internet
Televison & Video Logo
14 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
