Question about Lexmark X8350 All-In-One InkJet Printer
Can't recieve faxes
Tried everything. Charter communication says things are working right! they said call you!!
    Genius:
  • 2,120 Answers
Call your fax machine from a regular phone and listen for fax tones.
is your phone line DIGITAL such as DSL or Vonage?
Posted on Jan 23, 2009
Epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
Why is my fax machine not working? it reads no dial tone when i try sending a fax and i cant recieve either
make sure it is plugged in right in the back.try using a different phone jack in the house
Jul 12, 2009 | Epson Stylus NX300 All-In-One InkJet...
Same problem
press the setup button and scroll down to tools.
in tools there should be an option that says run fax test.
that would give you a printed page as to which part of the hardware of the printer or the fax line failed.
What your error code means is(look below)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jun 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Incoming fax freezes system
Try installing the fax controller again, make sure to turn off fax machine, reboot computer and then after trying turning on your fax and send another document.
Nov 18, 2008 | Symantec WinFax Pro for PC
I am unable to recieve a fax
have you tried a firmware upgrade, depending what happens with the fax tones depending where the fault is. can you ring into the machine? other thing to try is put a handset in the line and dial out or listin to the line?
so many things come in with problem sending and recieving faxs. have you tired putting on ECM mode?
Oct 21, 2008 | Brother Office Equipment & Supplies
Fax
hook a phone to the line if you get a dial tone, and can dial out it is not the line, make certain the phone line is connected to correct phone jack port on the machine. there is usually phone and a line on there. connect it to the line.
What happens when you try to fax, do you get an error, what is that error. try to manually fax something.
Oct 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
Brother mfc-7420n fax not recieving faxes, disconnecting
Please double check all cords and besure you are in the right plug.
Mar 27, 2008 | Brother MFC 7420 All-In-One Laser Printer
Lexmark 3400
printer screen shows cover open but it is,none buttons will work
Jan 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Can't recieve a fax
i have fax L100 ,i can send a fax but i cant recevie a fax error is communication error (003F)
Oct 24, 2007 | Canon FAX L-120 Plain Paper Laser
Faxing
Make sure that you have settings to RECIEVE FAX.
Go to start on your Desktop. Click on All Programs. When window opens, click on accessories. When accessories window opens, click on COMMUNICATIONS. When the Communications window opens, click on Fax. When the Fax window opens, click on FAX CONSOLE. When the FAX CONSOLE window opens, click on RECEIVE FAX NOW.
You might have to wait until your telephone/fax machine, rings and then click RECEIVE FAX NOW if it does not work automatically.
The person who is sending you a Fax might have to inform you they are sending a Fax to you right now.
Hope this is helpful to you. Good luck.
Sep 30, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark X8350 All-In-One InkJet Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
