Question about Mercedes-Benz Mercedes Dvd Wireless Headphones Set
Can't connect Mercedes wireless headsets - Mercedes-Benz Mercedes Dvd Wireless Headphones Set
Plugged in it flashes red, unplugged is unresponsive.
You also need to turn on your phone's bluetooth, and get them connected so that it works, otherwise, it could not.. Flash red means it's charging right now.
Android 4.0 Tablet PC
Jan 07, 2012 | Just Wireless Bluetooth Headset Wireless...
How do you hook up a ps3 to a plantronics cs70
Sorry Nancy but you can't connect a CS70 to a ps3. What Plantronics has available exclusively for Playstation 3 is the Gamecom P90. It's a bluetooth headset.
Good luck from Headsets Direct!
Dec 24, 2011 | Plantronics CS70 Wireless Headset
How to connect phone to plantronics bluetooth just wont connect
Once you make your cell phone discoverable, put the Plantronics Explorer 320 headset into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link for the Explorer 320 User's Guide with the pairing instructions.
Sep 29, 2011 | Plantronics Explorer 320 Wireless Headset
I CAN ADJUST VOLUME ON HEADSET, BUT I DONT HEAR A DIAL TONE OR VOICE THRU HEADSET
You don't specify which headset that you have. I would need to know which one and check all the connections to know why you aren't hearing a dial tone.
Here are a few things you can try -- try checking all the connections, unplug and replug back in, make sure that they are in the correct slot.
If it is a wireless headset say like a CS50-CS55 there is a 1-4 on the side, check to see if the #1 is in a 3 O'Clock position.
Is this a computer headset, wireless, corded, bluetooth, MP3?? Can only give recommendations of things to try.
Aug 24, 2011 | Plantronics Radio Communications
I have a snom 370 voip phone with the plantronics cs70 headset but there's a bad echo on the callers end so i got the snom wireless headset adapter but i don't know how to connect it. i also have...
We've never dealt with snom wireless adapter but the CS70 and HL10 lifter is a popular set for your phone. there are a couple of things you can try to cut down on the echo.
1. Make sure CS70 is proper distance from phone, minimum of 6" (12" from a PC)
2. Make sure round compatibility dial (located on left side of base) is set correctly. Most phones work on setting #1 (never between numbers)
3. Echoing is usually caused by an improper mix of incoming and outgoing volume. With a friend listening in you can make broad and minor adjustments for both (incoming: back of base (1-4) and +/- on headset; outgoing: bottom of base (a-d) and +/- arrows on back of base).
Following these steps should help you out.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics CS70 Wireless Headset
I lost my manual and i need connect with my phone.. How do you connect ?
Can't say for sure without knowing what type of headset, but most that I've used you can reset by holding the connect button down for 5-10 seconds and you will hear a beep to confirm it's reset. If you are asked for a password, try 0000. If not, try 1234. Go to your phones menu and enable the bluetooth. The phone should then search for available bluetooth devices in the vicinity. It should then find your headset. You then need to agree to Pair the device with your phone.
Jun 20, 2011 | Just Wireless Bluetooth Headset Wireless...
Blueparrott b250-xt want power on
Hold down the Multifunction Button ( Please refer diagram shown below ) for 2-3 seconds until you hear 2 rising tones.The yellow light will flash every 4 seconds.After the headset is turned on, it will attempt to connect to the last device that it was paired or connected with if that device is available
ie.powered on and within range.Otherwise the headset will remain in the 'on' state.Your valuable feedback would be appreciated.
Jun 03, 2011 | Parrot Blue Wireless Headset System...
I can't connect my bt-15k2 to my LG phone
Hi desireeveiga,
I see that you need assistance in getting your BT heatset to your LG phone.
make sure that the BT headset is set to discoverable mode, I believe there is a connect button on the headset that you can press and hold down for a couple of seconds this should lit up a light meaning that the BT headset is ready to be discovered by a device.
Once the Headset is set to be discoverable you can try and get you LG phone to detect the headset, Once detected the pairing code should be standard try 0000 this should get the BT headset connected to you LG phone.
I hope that this can help.
Have a nice day,
mvincentc
May 31, 2011 | Just Wireless Bluetooth Headset Wireless...
The headset connects to the phone but then it says connecting and then comes up bluetooth connection failed and it wont work hands free, it has the blue symbol on my phone screen but wont it wont connect...
I would suggest turning off your phone and headset. Turn your phone back on and put the headset into pairing mode (the headset needs to be turned off when starting the pairing mode) pull up your menu on your Bluetooth phone and try reconnecting the two again.
Below is the Explorer 320 User's Guide for more information.
Plantronics Explorer 320 User's Guide
Apr 27, 2011 | Plantronics Explorer 320 Wireless Headset
My Just Wireless BT-15K will not charge. i returned the first one and the second one has the same problem.
heres wat u do shove the whole thing including the box up there *** then by a different headset from another store :)
Nov 28, 2010 | Just Wireless Bluetooth Headset Wireless...
Mercedes-Benz Mercedes Dvd Wireless Headphones Set Logo
333 people viewed this question
Top Mercedes-Benz Audio Players & Recorders Experts
xxxxxx xxx
ray gallant
Robert King
Level 1 Expert
Are you a Mercedes-Benz Audio Player and Recorder Expert? Answer questions, earn points and help others
