JVC CD Player carousel tray doesn't align correctly
My JVC XL-F211TN 5-disc carousel CD player doesn't work correctly. When I try to play it, the tray doesn't align correctly with the laser hole and the display shows the CD that is supposed to be playing as another one. Example: The tray closes with disc #2 closest to the laser hole, but disc #5 is displayed as the one ready to play on the display. Also, the Disk Skip button won't rotate the tray of the player when it's pushed. It's says on the display that it's skipping to the next CD, but the tray doen't move (except when I push the Open/Close button). Also, the Power button doesn't turn off the CD player most of the time. I have to turn off my power strip & turn it back on to get the player into Standby mode.
5 Suggested Answers
SOURCE: cd stuck in
take the cover off and take the CD out
Posted on Jun 19, 2007
bluenadas
  • 203 Answers
SOURCE: cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
Posted on Nov 21, 2007
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
SOURCE: CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Posted on Dec 04, 2009
Tray will not open
It sounds like the CD is not in the correct location. Tap it gently in several directions, try this several times it may solve the problem. I think you will have to open it up and align the tray assembly and remove the offending CD.
Oct 30, 2015 | Sony 5 Disc Cd Player Carousel Cdp-c615
I HAVE A 5 DISC CHANGER.......I PLUG IT IN, TURN ON POWER AND THEN PUSH OPEN. OPEN COMES UP ON THE SCREEN BUT THE TRAY DOES NOT OPEN. WILL NOT SKIP FROM ONE DISC TO ANOTHER EITHER???????? ANY...
The 5 disc carousel CD player has a belt driven mechanism in it. And after about 3-4 years the belt looses its tension and cannot push the tray in or out. If you keep your ears on the top cover and turn on the system you will hear a whirring sound coming from the inside which will prove my point.
There are two belts in the machine. One for the eject mechanism and the other for disc change mechanism. One has to seek professional help to replace both because there is timing sequence also involved like the cam shaft of an engine.
Mar 08, 2011 | JVC XL-F154BK 5-Disc CD Changer
Jvc xl-f254 cd changer for home. 5 disc changer. Carousel will not slide out. makes humming noise, possibly trying to open.
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Jan 29, 2010 | JVC XL-F254BK 5-Disc CD Changer
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
On my JVC TH-60 disk drawer will not open?
hello the problem you have is that the tray is not in time so the security switch dont let to open this try to get ifo how put on time or align the mark on main spindle against the small one hope you undrstood saludos
Jan 08, 2009 | JVC XL-F154BK 5-Disc CD Changer
Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
Dec 27, 2008 | Sony CDP-CX53 51-Disc CD Changer
JVC XL-SV22 Video CD
if cracks having in disc mean some times header does read disc! clean your header with disc cleaner!
Jul 01, 2008 | JVC XL-SV22 CD Player
JVC 5-Disc Player XL-F115
You won't get any sound unless you connect your CD player to an appropriate input on your amplifier (any but phono or tape/md) and connect your speakers to this amp.
Shout if you need more help.
Dec 30, 2007 | Audio Players & Recorders
Player only plays first 3 tracks on CD and then stops
the emitting diode is not shiffting right..it might need some cleaning of its track..open it and check it out. good luck
Apr 05, 2007 | JVC XL-FZ258BK 5-Disc CD Changer
240 people viewed this question
 Grubhead
Grubhead
