Question about Locks & Locksmithing
Factory code for a micro fridge electronic safe ex2004132164
2 Suggested Answers
SOURCE: Forgot code to open hardline electronic safe
Change code to open hardline electronic safe
Posted on Sep 08, 2010
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
What is the factory code for a Sure safe? Some idiot locked mine before I had a chance to set it.
there is no "factory" code STUPID if there was a factory code then everone can open your safe then. have your IQ checked no wonder you got your life in so much trouble locking yourself out, this very question proves it. Let me guess further the type of life you have: you are also in debt and underwater, about to loose your house, have a failed business, and close to loosing your job VERY soon, unsatisfied with your life, with nothing sucessful accomplished in life, driven by greed, you have been a complete failure, a liability to society. is my predictions about 99% correct???
Mar 29, 2011 | Safe International Digital Electronic Safe...
I forgot my safes password
call a local locksmith he can help, if it can not be opened you may have to bust it open, call some one with many tools they may help. I recommend an angle grinder this will cut through steel. If you can remember where the pins are that hold the door closed you can grind through the side and cut the pins with two cuts. would take ten minutes to open with this method. There is probably an upper and lower pin.
Apr 01, 2010 | Safe International Digital Electronic Safe...
Kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
Feb 24, 2010 | Safe International Digital Electronic Safe...
Opened micromark safe using factory code, how do i change this to a personel number ?
Hi have micromark electronic safe no EX2003085561 when i enter code top right hand green light flashes and lock will not open any assistance gratefully accepted
Stewart
Nov 23, 2009 | Safe International Digital Electronic Safe...
What is the factory code for kingavon safe 25
how do i change code on my safe kingavon 25, i can open and close with my existing code just need the instructions to input new code thanks
Oct 10, 2009 | Safe International Digital Electronic Safe...
Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Mar 22, 2009 | Sentry Fireproof Safe
Locks & Locksmithing Logo
535 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
