Question about HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory
My Printer has an Error Message saying "card slot not Initialized
I cannot print anything! when i check my printer thats all it says!! "Card Slot not initialized"
    Genius:
  • 2,120 Answers
Try this.
1. Turn the printer on.
2. When the memory count start Press and Hold the "Menu" button.
3. Release the "Menu" button when all 3 LEDs are illuminated.
4. Press the 'back' button.
5. The display will then show "Initialize disks".
6. Press the green "Check" button to start the process. This will take some time.
7. The printer will automatically come back to "Ready" after this procedure.
If the above doesn't work, you may have a bad memory card.
Posted on Jan 23, 2009
What does the error message EI0 1 Mean on the 8150dn printer?
EIO is the External Input Output slot that is on the formatter of the printer. the 8150 has 2 EIO slots (EIO 0 or EIO 1). One of the slots is probably the JetDirect card (network card) for the printer. The second slot might be a hard drive but is usually open.
If you are getting a EIO error first try reseating the JetDirect card (power off the printer first). If you are still getting the error pull the card and power up the device with out the card installed. if the error goes away power down the unit and install the card in the other EIO slot. if the card works you have a bad slot on the formatter but you should be good to use the device. If you get another EIO error the card is probably bad.
Mar 10, 2015 | HP LaserJet 8150 Printer
My HP 4100tn will not print and I am getting error message as follows: 82.0180 EIO 2 ERROR I printed a document and then when I tried to print another document I got the error message. How can I fix...
Thank you for contacting FixYa with your printer inquiry.
This is an error caused by the jet direct card in your printer, try one of two things.
  1. Move the Jet Direct card from port 1 to port 2 on the printer.
  2. Replace your jet direct card with one that you know is good.
Test to see if either of these resolves the issue.
The problem is usually a faulty card.
J7934-69011 JetDirect 620n internal print server - 10BaseT and 100BaseTX LAN interface board - Plugs into peripheral EIO slot - Has an RJ-45 connector
Vender
http://www.dectrader.com/J6057-61001-New-HP-JetDirect-615N-internal-print-server-10Base-T-and-100Base-TX-LAN-interface-board-Plugs-into-peripheral-EIO-slot-Has-one-RJ-45-connector.html?utm_source=googlebase&utm_medium=shopping&utm_campaign=parts
image.php?type=p&id=223008&t250=y
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 22, 2011 | HP LaserJet 4100n Printer
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
Sd slot used to read cards, now "memory card error"
i am trying to copy my photos from my 4 GB SD memory card on to my computer through my printer HP PSC 2355 all in one printer. But as soon as i put the card into the slot it turns green and the a couple of minutes later turn Red and flashes and i cannot read it on my computer
Dec 04, 2009 | HP Office Equipment & Supplies
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
Display reads "card slot not initialized"
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
Error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
May 24, 2008 | Lexmark P915 InkJet Photo Printer
Error. Power Off
You have Firmware problem.You must download latest firmware for this machine. After that copy firmware files on CF card type 1. Just put CF card with files in CF card slot in printer( There is slot on the back side of printer.If you have network card you must remove it to access slot.Switch on printer.....After correct download all LEDs blinking.Switch OFF and remove CF card.
Oct 23, 2007 | Kyocera FS-2000D Laser Printer
My Printer Has A Mysterious Memory Card Problem?
Check the slot for a card detection switch, it may be stuck so the printer thinks there's a card already.
Aug 09, 2006 | HP PhotoSmart 7350 InkJet Printer
HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory Logo
2,581 people viewed this question
Ben Johnson
