Air conditioner stuck in economy mode - Heating & Cooling
3 Suggested Answers
  • 42176 Answers
SOURCE: my peguoet 206 1.9 is stuck in economy mode how can i tix this
Have the fault codes read. Replace faulty items. Use only
genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units. This results in the fault codes not cancelling out.
Posted on May 19, 2013
  • 42176 Answers
SOURCE: how do i get my peugeot 206 1 9 diesel out of economy mode
you may need a reader unit to reset the cpu.
My Fujitsu air con keep flashing operation,timer and economy .off the plug took out and on back still the same.took out the batery from remote and put back still the same..plss help me
It's asking you what mode you want to run your unit in. Do you want to run it in heating or cooling (operation), do you want to run it with economizer mode (economy), or do you want to run it with a timer setting (timer). Do cooling, no economizer, and no timer. This will make your unit run off off the setpoint you want. I.e. 72 degrees
Aug 05, 2016 | Fujitsu Heating & Cooling
Hi I have a Moretti 1800BTU portable air con and its started beeps 10 times on and off throu the day and night
Liza I hope you still have your owner/operator manual it sounds like to me its set up on economy mode. Check your operators manual and check set up.
Dec 29, 2014 | Heating & Cooling
My peguoet 206 1.9 is stuck in economy mode how can i tix this
May 18, 2013 | Cars & Trucks
Does the fan shut off once the air conditioner reaches the temperature selected by the owner or does it continuously run when the air conditioner is on?
If this is a multifunction unit (AC/Dehumidifier) and you have it set on Dehumidify Mode as well as AC, yes , it will continue to run. If you don't have unit like this, but maybe have an economy mode, it will continue to run for awhile too. If you have neither, then no, it should stop running soon after the compressor turns OFF.
Hope this helped you.
Jun 22, 2011 | DeLonghi Heating & Cooling
What is the "eco" mode
economy mode uses less energy while cooling when it room reaches tempreture it reduces the amount of running time for the unit
Dec 12, 2010 | Heating & Cooling
It runs awhile then beeps and shuts off
hello
Is the unit set for economy or on a timed mode?
If so, set it for cool .
Aug 29, 2010 | Fedders A6X05F2G Wall/Window Air...
What's going on -- Vents are blowing hot air and
It sounds like the unit is stuck in the heat mode or the thermostat switch is still on heat. If the switch is in cool then you can go to the outside unit and locate the reversing valve. It may be stuck in the heat position. You can tap it with the handle of a screwdriver but only on the ends and very lightly because if you dent it the valve will be stuck for sure. If it shifts you will hear a loud hiss as the pressure equalizes. You could also try unplugging it from the circuit board. On some units it is energized in the cool mode and on others it is energized in the heat mode.
Jun 05, 2010 | Whirlwind FH-778 Air Conditioner
Abbreviation definitions.
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
Oct 16, 2009 | Ruud Central System Air Conditioner
Air conditioning noise
it is normal the computer adjusts the engine rpm in economy mode to save gas out of economy mode everything runs a little more because the computer is'nt holding them back
Oct 16, 2009 | 2002 Saab 9-5
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
