We don't have a dedicated fax line, but we can't seem to get it to work when we pick up manually
For receiving a fax, its not necessary that you should have a dedicated fax line. But in case you are using a voice mail over the same phone line in which you receive faxes, it may interrupt it. So its recommended to use a Distinctive Ring Pattern, which will be provided by your phone vendor. However before trying it try to do a power drain in printer. To do a power drain, you need to dixconnect the printer for power connection, leave it for few minutes than replug it. Else try a reset on the printer, try to unplug the power cable, press and hold # and 6 on the pritner while power cable is unplugged , and than while holding the # and 6 button replug the power cable back to unit. It will reset the printer to factory defaults. This should work....
Posted on Jan 22, 2009
Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
Set the desired print quality, and you are ready to receive faxes.
Mar 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Aug 02, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Jun 12, 2009 | Ricoh Aficio 1232C Color Copier
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Apr 14, 2009 | Xerox WorkCentre M15i Laser Printer
Nov 09, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Aug 20, 2008 | Brother Office Equipment & Supplies
Aug 17, 2008 | HP Officejet 4110 All-In-One InkJet...
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Jan 23, 2007 | Canon FAXPHONE L170 Plain Paper Laser
