Question about Lexmark X3350 All-In-One InkJet Printer
Windows Vista Compatibility
Even after downloading the Windows Vista Driver I get the following message: AIOC exe has stopped working A problem caused the program to stop working. Windows will close the program and notify you if a solution is available.
By the way this is and e-machine I have the Lexmark 3350 all in one printer I bought a new E-machine computer and it has windows VISTA I called tech support and they directed me to install and update which I did and now I get the same "AIOCexe has stopped working ect ,,,,,"!
  • step15 May 11, 2010
    fix my printer
I had to go to my firewall and check the history. I happen to be running the Norton firewall right now and the Lexmark interface was marked as "auto" for access to the Lexmark site. I changed the setting to "Allow" and it immediately began to print. I am using the cjr3300en driver which is the current listed on the Lexmark site for Vista.
Posted on Jan 28, 2009
Lexmark website will have all drivers necessary for you to reload, after you have installed if you have a problem see the following explanation.
This behavior occurs if a non-Vista driver, such as a Windows XP driver from the printer's original driver CD, is installed in Windows Vista.
1. Unplug the USB cable from the computer.
2. Download the cleaning utility for your printer from
3. Double-click on the cleanup utility and follow the on-screen instructions to run it.
4. Restart the computer.
5. Reinstall the Vista driver that is available for the printer on the Lexmark Web site.
Posted on Mar 03, 2009
Got a HR8 Genius scanner working with win7-64 until upgraded my system to win8 - 64bit and stop working. Tried the compatibility mode and nothing... any solutions?
How to Install Scanner ColorPage HR8 Geniuns 64-bit Windows 8.1
Getting Driver Genius for Windows Vista
Microsoft reports no drivers from the manufacturer, to try luck with the driver of windows Vista, but does not explain how to make it work.
After you download the driver, you have to run the "setup.exe" in support "Windows Vista" mode.
But before you do read the following explanation because you have to do something else before I install it, otherwise it does not work.
As I said, after trying I did not recognize the driver, I tried to take the driver manually
but windows saying that the driver was not digitally signed and you can't install if driver is not signed.
I Search the web such as disable that control and found a step in the url:
After following the steps I could install the scanner driver and HR8 works correctly in Windows 8.1
Now you can run the setup.exe in compatibility mode with Windows Vista, at the end makes restart the computer,
Now you got the scanner Genius ColorPage HR8 running on Windows 8.1
Sep 28, 2013 | Genius ColorPageSlim 1200 Flatbed Scanner
Oregon trail 5th edition vista
Please check the compatibility of the game with Vista, and am not sure if this compatible at first place. Secondly you can run programs or games in XP mode by right clicking on the exe file of the game, goto properties and select compatibility, and then select to run in XP mode. Hope this helps
Nov 05, 2009 | The Learning Company Oregon Trail 5th...
Downloaded driver Lexmark for x9350 Prints - Software Does Not
You would need to download the Vista 64bit package of Lexmark Productivity. Install this version and you should be all set. Hope this helps.
Aug 13, 2009 | Office Equipment & Supplies
Dell A920 with Windows Vista
That A920 is working with vista, here is the drivers for thet:
Dont forget to download and install the application to, you need all the files on that site
For that 968 printer, uninstall it, download the files from the link below and reinstall it, that will make your printer work again
Let me know how it goes
Good luck
Mar 30, 2009 | Office Equipment & Supplies
Aioc.exe has stopped working lexmark 5400
this usually happens when you try using the old cd on a vista os.. most of the time the cd was made to work on xp only since during the time of release of those printer, vista was not yet out of the market.. try downloading this patch
disable user account control first.. you can do this in msconfig on the tools tab then run the patch
chose the right series of you printer.. normally when you run the file it will extract the file and run the patch.. cancel the application after extracting the file..
go to c drive on you computer... look for the folder LxkPatchAIOC
go inside the folder and look for the word aioreg.. right click on it and choose merge...
that should fix the issue..
if in case it didnt work on you... try calling 1-800-lexmark
you can email me at for more questions about lexmark
Mar 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
What you need to change is your screen resolution to either 800 x 600 or to 1024 x 768 (in your desktop settings)
What is happening is that your Lexmark all-in-one center doesn't think your monitor can handle the program (or something to that effect).
You will NOT have to restart your computer either.
Just restart your Lexmark All-In-One program and you can start scanning.
Aug 25, 2008 | Lexmark X7350 All-In-One Printer
Mar 16, 2008 | Lexmark X1240 All-In-One InkJet Printer
Haveing trouble installing logitech quick cam onto my comuptor thats running windows vista
This problem was caused by a compatibility issue between Windows Vista and Logitech QuickCam Messenger.
Logitech QuickCam Messenger was created by Logitech, Inc..
To search for similar devices that are compatible with this version of Windows, visit the Windows Vista Hardware Compatibility List website online.
However, it’s not totally out of hope for owner of Logitech QuickCam Messenger who has upgraded to Windows Vista. The following hack will use Windows XP driver (a common trick to use non Vista compliant device) to install the webcam in Vista:
  1. Download QuickCam 8.4.8 with driver for WinXP.
  2. Install WinRAR if not already installed yet.
  3. Open the setup installer qc848enu.exe and unpack its contents to a folder. Alternatively, right click on qc848enu.exe and select “Extract to qc848enu\” option.
  4. Insert or plug in the Logitech QuickCam Messenger to a USB port if not already done so.
  5. An “Driver Software Installation” icon in systray (notification area) should appear, which will pop up detailed message if click. It should fail, and “Add Hardware Wizard” dialog window will appear. Choose to install the driver manually by instructing the Wizard to locate and look for the web cam driver inside the Drivers folder under the unpacked folder of the qc848enu.exe setup program. You can use browser button to select the folder.
  6. Windows Vista should grab the XP driver and install it properly.
  7. Download the latest version (10.5.1) of Vista compliant QuickCam software from Logitech to install the software on Vista.
  8. Run the setup (qc1051enu) normally. You may need to skip the detection of webcam near the end of installation process.
Voila, you can now use the Logitech webcam to capture images or use it in conjunction with video chat in IM programs such as Windows Live (MSN) Messenger, AIM Messenger, Yahoo! Messenger, Skype or run Logitech VideoCall.
i hope thist post can solve your problem
Mar 14, 2008 | Logitech Webcam
JANOME dIGITIZER 10000 - "JANOME.EXE has stopped working"
Digitizer 10000 v2.21 might run in compatibility mode on Vista, but there's no gaurantees. Even the latest digitising suite Digitiser Pro/MB is experiencing problems running in Vista 32 and as yet has no real fix (driver) for Vista 64.
Dec 29, 2007 | Janome Memory Craft 10000
Lexmark X3350 All-In-One InkJet Printer Logo
691 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
