Question about Samsung Q430 Laptop
Samsung q430 stuck splash screen
Laptop was dropped on carpet from a small height after I sneezed. Afterwards a sort of "chuckling" beep can be heard. I did a hard restart to find the beeping noise occurs for about 3 seconds and the laptop is stuck on the first loading screen. f2, f4, or 8 booting options do not work, nothing happens.
  • Samsung Master
  • 7,627 Answers
Unplug, remove battery, plug in, try to reboot. If that doesn't work, unplug open Memory Bay, reseat Memory Mods. Open the HDD bay, reseat the HDD. You may have jarred something loose. One can only hope you didn't damage the HDD.
Posted on Jan 12, 2013
  • 3 more comments
  • mickomoo Jan 12, 2013
    The memeory seems to be in place, but I reseated it just to be sure, however I don't want to remove the HDD without tech support. This is just being proactive but is there anyway to tell if the drive has been unsettled by looking at it?
  • max carson
    max carson Jan 13, 2013
    No, most likely, If the HDD has been damaged, it's the actuator arm that's out of line. It doesn't take much of a bump.
  • max carson
    Samsung Support:http://www.samsung.com/us/support/owners... ,
  • mickomoo Jan 13, 2013
    You've been extremeley helpful and quick too, thank you so much! I think I found the problem. I took it to the shop and it's dead, it won't power on. Either way I figured I would need a new HDD when I heard the noise.
  • max carson
    Thanks, Let us know the outcome. Replacing the HDD is the easy part, your OS and ALL your data is quite another issue.
  • 26 Answers
SOURCE: won't boot past windows splash screen
Hi, i personally think u that if u have tried a repair and it failed, then install another Os but dont format, but still install it on the same partition or different so that u dont loose you data, but i personally think its a virus problem, may be u can also try getting an external casing for sata drivers, then put in you hard disk and scan it from so pc with a good antivirus it u dont find any thing, then it means that its you drivers so i think if u can go to the bios and disable all the device like audio, Lan, wireless etc.
The other problem that would bring that, would be raid support, try the changing your raid to native. so that it supports both IDE and Sata, i will just emulate sata raid to IDE. anyway u try that, hope it helps.
Cheers
Posted on Apr 27, 2009
  • 8909 Answers
SOURCE: Samsung mini laptop n148. Windows
It sounds to me that unfortunately you have an error on your recorded CD and there will be nothing you can do to repair that.
The installation of Norton should not cause the problem itself an error on the hard drive will usually cause that problem.
Posted on Oct 23, 2010
akashgupta27
  • 139 Answers
SOURCE: How do I change the lcd screen in my Samsung q430
may be this video can help..
Posted on Jan 06, 2011
  • 3 Answers
SOURCE: My Samsung R530 will not
If you have the restore disk use it to do a repair but I would recommend to reinstall the operating system
Posted on Jan 30, 2011
redstricted
  • 31 Answers
SOURCE: I bought new Samsung Q30
Hardware problem, the speakers are no good, try using your headphones or connect them to external speakers.
Posted on Mar 08, 2011
Laptop key popped off
restart everything(each part) individually
Feb 16, 2014 | Samsung Q430 Laptop
WHITE SCREEN ON SAMSUNG LAPTOP
Prior to the Windows splash screen do you see graphical issues ( black background, white writing, or bios splash screen) if you don't then the problem is with windows and will need to be reinstalled. Samsung ship laptops with a windows cd and is a fairly basic wizard. If you don't know how to do this google is full of guides. If you however see graphical problems right from turning the laptop on then there is likely to be a hardware fault straight from the factory. Contact Samsung and they will repair / replace the laptop through warranty. I have seen several Samsung laptops brand new from the box do this and It turned out to be a hardware issue and was replaced on warranty. Good luck.
Apr 17, 2013 | Computers & Internet
How do I create a Samsung Recovery Solution area on my hard disk drive so I can install it?
Go to this link http://comps-tech-solution.blogspot.in/2013/09/create-samsung-recovery-partition.html
Apr 14, 2012 | Computers & Internet
My Q430's power connection is loose and not changing battery. Do I have to swap out motherboard?
The DC Power Jack is the jack you plug the AC adapter (Charger) into. (DC_IN)
The DC Power Jack for the Samsung Q430 series of Notebook PC's, consists of a;
1) DC Power Jack, which is connected to two wires.
2) The wires end in a small male plug connector.
It is now a DC Power Harness,
http://www.laptopjacks.com/part/Samsung-Q430-DC-Power-Jack-J-SM371300C1.html
FOLLOWING Anti-Static Procedures, the laptop is disassembled far enough to unplug the DC Power Harness, and plug a new one in.
Regards,
joecoolvette
Sep 10, 2011 | Samsung Q430 Laptop
Brandnew Samsung Q430 freezes regularly for anything between a couple of seconds till several minutes, in any programme which is then displayed as 'not responding' while the harddisk light is continuously...
It sounds like your hard drive is defective and not working properly, you pointed out this is brand new machine and should be under warranty, if the vendor is not prepared to back what he sells, I suggest you get in touch with Samsung to see if they can remedy the situation because you should have a manufacture warranty on the product.
Apr 15, 2011 | Samsung Q430 Laptop
Samsung tocco
well this is not the screen's problem .if the screen of your phone is alright then its some internal repairable problem . the chances might be dat any wire point of screen touch will be damaged and can be reapaired easily. so dnt worry be happy
Oct 23, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung Q430 Laptop Logo
210 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
