Question about Epson Stylus CX4200 All-In-One InkJet Printer
Epson CX4200 prints test page fine, but cannot print in black
If I print an XP test page, it comes out perfect, but when I try to print an all black document, with no colors, it comes out "greenish" and the test is not solid, it has gaps. There is no grayscale option that I can find in the printing prefs for the cx4200.
thanks for any help.
ohms
  • 1879 Answers
SOURCE: Color printing problem for Epson CX4200
try this :
Please confirm that the head cleanings were done using the most effective method listed below.
1) Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Posted on Jan 03, 2008
Metawatch
  • 96 Answers
SOURCE: my epsonstylus cx4200 wont print with black ink.
Please ensure that you have removed (Completely) all yellow tape on the top of the cartridge.If it is not completely removed a vacuum can form preventing the flow of ink.
Run a few cleaning cycles.
Try a local print test...
As for thr G4 sorry but I can help you except to power off all devices, power up and reboot.
Posted on Feb 09, 2008
  • 91 Answers
SOURCE: epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
9. Close the ink cartridge cover and press it until it clicks into place.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Posted on Mar 19, 2008
Basti
  • 1447 Answers
SOURCE: changing the ink cartridge in Epson Stylus CX4200
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Posted on May 15, 2008
  • 300 Answers
SOURCE: Receiving a wide band in
Clean the scanner glass, clean the scanner
If you are unsure how, download the cx4300 reference guide from the link below (yours is discontinued) click on scanner then maintenance -
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cwi+TwtWff3Y5azz8r1PYz8&tc=5
Posted on May 25, 2008
Cx4200 does not print black
If the nozzle test doesn't print black, then no black ink is flowing.
Run a "head clean", and do the nozzle check again.
Feb 19, 2015 | Epson Stylus Office Equipment & Supplies
Epson t60 is good printer ?
Hi global_sreek,
EPSON is Super fast, affordable & powerful for all your professional photo printing needs.
Features
Increase your productivity with super-fast print speed
• Print instantly from your computer screen at a fast print speed of 12 seconds per 4R photo
Maximise savings with Epson INKdividual™ Cartridges
• Maximise savings and minimise wastage by replacing only what you need
• Epson 6 colour photo ink is highly affordable, keeping daily running costs low
Perfect printing onto CDs / DVDs
• Print directly onto the printable surface of your CDs/DVDs
Compact size to fit any space
• The Epson Stylus® Photo T60 is so compact, it takes up little precious studio space,
freeing it for other uses
Photo perfection with Epson Creativity Suite
• A powerful photo editing software that lets you perfect your photo prints with just one
click of a button
SPECIFICATIONS
Print:
Ink System - 6-colour
Ink Type - Photo Dye(??¥?œ¬??ž?®??š??¼??¸????₪œ?´¢ )
Max. Print Resolution - 5760x1440 dpi (with VSDT)
Min. Ink Droplet size - 1.5pl
Print SpeeD - Approx. 37ppm (Black) Approx. 38ppm (Colour)
Connectivity and Compatibility:
PC-less function - No
Index Sheet - No
Connectivity - Card Slot - No
Connectivity - USB Cable - Yes
Connectivity - Wireless - No
Interfaces - USB 2.0 Hi-Speed
OS Support - Windows 2000/XP/XP-x64 Edition/Vista Mac OS 10.3.9 or later with USB
Network - No
Adobe Postscript - No
Memory Card Backup - No
Ink Cartridges:
INKdividual - Yes
Ink Cartridge Model - 85N Ink Series (Standard Capacity)
Media:
Media Model - S041926E1; S041927E1; S041863; S041464E1; S041285; S042070; S041925; S041332; S041786, S041259
Paper Handling:
Max. Paper Size - A4
BorderFree - Yes
Max. Paper Capacity - 120 sheets
Roll Paper - No
Tractor Feed - No
Cartridge Model(s):
85N (Standard Capacity Black Ink) - Approx 540 pages (ISO/IEC 24711 and 24712 Test Suite)
Page Yield (pages):
85N (Standard Capacity Colour Ink)* - Approx 860 pages (ISO/IEC 24711 and 24712 Test Suite)
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Epson TM-T60 Printer
HOW TO print a test print?
click start, printers and faxes or devices
right click on printer and click properties
click print test page
Oct 28, 2010 | Epson Stylus CX4200 All-In-One InkJet...
My Epson CX4200 is printing pink pictures - help!
try printing the nozzle check page.. you will be able to see which color that is missing... it should have Yellow , Megenta, Cyan and Black... if any one of the color is missing.. try performing head cleaning and after twice cleaning and still no improvement, very high possibility your print head is clogged..
May 20, 2010 | Office Equipment & Supplies
My Epson Stylus CX4200 will not print because my Cyan ink is out. I tried printing in black and white only but still won't print because of the one empty cartridge. Is there any way I can still print...
I have a CX4800 and after clicking Print, I click Properties, then check Black ink only (is this how you are printing black and white - or is your document black and white)
If you haven't tried this option - it is worth a shot.
Mar 01, 2010 | Epson Stylus CX4200 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Epson Stylus CX 4200 won't print color copies of anything
Uninstall the printer software.
Restart your computer.
Download the latest drivers and software for the printer.
Load the software.
Part of the software could have corrupted itself...
Jun 11, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Prints grey not black
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Feb 25, 2008 | Epson Stylus CX4200 All-In-One InkJet...
My epsonstylus cx4200 wont print with black ink.
Feb 09, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus CX4200 All-In-One InkJet Printer Logo
118 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
