Programing the one touch dialing
How do I program the one touch keys?
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    RTFM it's on page ID 10T
    Genius:
  • 2,120 Answers
On what model?
Posted on Feb 28, 2009
EXECUTONE 64800 PHONE, HOW TO PROGRAM STATION SPEED DIAL # 'S
from the phone press program key, than 01 for speed dial 1 and then the phone number you need to program in under speed dial 1, after done, press program key. to dial out press outside line key, than program 01 and it will dial out to that numeber. you have 30 speed dials per phone.
Jan 09, 2014 | Executone 64 Corded Phone
How do i set speed dialing on my alcatel one touch 665
Here's how to program speed dial:
Menu->Settings->Phone Settings->Keypad->Numeric Keys
scroll to the key you want to program
select Dir. (brings up your directory)
scroll to the contact you want and press OK
Oct 16, 2011 | Cell Phones
Needs to reprogram fax machine, has old fax numbers in
1. Press Menu/Set, 2, 3, 1.
2. Press the One Touch key where you want to store a number.
The LCD shows the location you selected.
3. Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter a pause in the dialing sequence (for example, to wait for an "outside line"), press Redial/Pause as you're entering digits. A dash appears on the LCD. Pressing Redial/Pause enters a 3.5 second pause when the number is dialed.
4. Use the dial pad to then enter the name (up to 15 characters), and then press Menu/Set. You can use the chart on page 4-2 to help you enter letters-OR-To store the number without a name, press Menu/Set.
5. Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
When you dial an auto dial number, the LCD shows the name you've stored, or, if you haven't stored a name, the number you've stored.
If you loose electrical power, auto dial numbers in memory will not be lost.
(For USA Only) One-Touch key 1 has been pre-programmed for the Brother faxback system. One-Touch key 2 has been pre-programmed for the CallManage long distance plan. You can override them if you wish.
Note If you need to store a pause longer than 3.5 seconds, press Redial/Pause two or more times.
Note - You can store Groups (for Broadcasting) on the One Touch keys.
Dec 11, 2010 | Brother IntelliFax-2820 Laser Fax
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Nov 28, 2009 | Minolta MF1600E Plain Paper Laser Fax
How do i set up speed dial on my DP80F fax machine and erase the old ones?
1. Display the TEL LIST ENTRY Menu by Pressing 'Menu' and scrolling down to 3. Group Numbers
2. Then Press '2' or scroll down to 'One Touch Keys'
3. Press the desired One Touch Key that you wish to program.
4. If the One Touch Key has not been programmed, follow the prompts on the screen and enter the desired information, pressing the 'Enter' key after each entry to move to the next field.
If it is already programmed the display will say "Already Assigned". Wait 2 seconds until it says "One Touch NBR" then select '1' to delete, '2' to modify or '3' to retain. If deleting confirm delete by pressing the enter key. If modifying, enter the new information, pressing the 'Enter' key to move to the next field.
Hope this helps!
Oct 15, 2009 | Toshiba DP80F Printer
How to program speed dial numbers?
To Set:
Do not lift handset
Press FNC button
Press the desired “One Touch” Key
Enter number to be stored (remember”0” for external numbers)
Press FNC button to save
To Dial
Lift Handset
8
Press desired One Touch key to dial
Jun 25, 2009 | NEC ETJ 16DD-2 Corded Phone
Program one touch button to send fax to multiple numbers
Setting one touch numbers:
press function 72
set
press 1 for one touch numbers
press a position on the soft pad example 01
enter fax number with round buttons
set
enter name with soft pad letters
set
continue with more numbers or press stop to end.
For GROUP DIALING
Setting Group Dial:
press function 73
set
choose group dial
set
press program 1
set
name the program such as field offices.
set
press the one touch numbers you entered in the first step for this group,,,,01,02,05,08,17 etc
press set
press stop
load document in feeder, press Program 1 key, START
Jan 23, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Speed Dialing
Press PROG press a speed dial button (ie 13-24) dial 9 plus the number press STORE
Carl
Oct 08, 2008 | Panasonic KX-T7731 Corded Phone
Programming the DSS/BLF
Need to login in system and program buttons from there.
Nov 07, 2007 | Inter-Tel Axxess Phone 5504400
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
jasbo
jasbo
