Question about Pentax Optio 43WR Digital Camera
Camera thinks SD card locked but it is not
Camera appears fine for all purposes. Slide in any SD card we have including new ones and it thinks the card is locked and won't shoot pictures.
  • Steve Hawkins Jan 09, 2008
    The suggestion was inappropriate since the card is not locked. Your comment above was very inappropriate and I hope you do not comment like that on other posts. We actually bought the camera new not on ebay thank you and it worked well for many years. Then one day it stopped working. I contacted Pentax who informed me that they could look at it for $150. I have tried various unlocking suggestions etc but figure the chip inside has gone bad. I instead went and bought a new Canon. Great camera. Thanks for looking.
  • Anonymous Jun 22, 2008
    My camera was working fine and i took out the memory card, put another one in and now it says that every memory card is locked. the slide on the card itself is not in the locked position and no matter if i put a new card in or one that i have had for a while it will not take pictures anymore.
  • 589 Answers
There is a little slide switch on the side of the memory card. Good luck!
Posted on Jan 08, 2008
  • brian c
    brian c Jan 08, 2008
    Thanks for the rating, you unappreciative prick. I'm sure everyone else will just want to jump in and help you now.
    In case you haven't realized, people tend to lock the cards because they think it locks it IN the camera, not realizing its a write protect for the card itself.
    Try reading the manual next time... or didn't your $50 Ebay camera come with one?
  • brian c
    brian c Jan 09, 2008
    What didn't you understand about my last response?
    This was your initial post:
    "Camera appears fine for all purposes. Slide in any SD card we have including new ones and it thinks the card is locked and won't shoot pictures."
    ***notice YOU typed "i think the card is locked"**
    This was my response:
    "In case you haven't realized, people tend to lock the cards because
    for the card itself."
    Perhaps if you specified that you meant the lock ON the card, I wouldn't of sent you the suggestion in the first place. In the future, learn to phrase questions clearly / properly to eliminate unwanted responses. Enjoy your new camera.
    Problem Solver:
  • 19 Answers
Try reseting the camera (check the manual for instructions) this sounds like an operating system issue which is just plain not fixable. Check in the SD card slot and look for dust or debris that may be irritating the works. let me know how it goes
Posted on Jul 07, 2007
SOURCE:
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
Why does "Card Locked" appear on my camera?
You neglected to specify the make and model of your camera so I'm going to assume it uses SD/SDHC cards.
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 27, 2012 | Cameras
I locked my card, not purposely and I don't know how to unlock it. Panasonic dmc fs4
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 17, 2011 | Panasonic Lumix DMC-FS4 Digital Camera
Card locked
Couple of things could be the problem one is that the card is actually locked and I'll include a diagram so you know where it's suppose to be and the other is the card may need formatting. The memory card when new needs to be formatted to the camera it is to be used in and after each time pictures are downloaded to the computer. Formatting cleans the memory card and makes it ready for new pictures to be loaded at optimum speed.
Here is the lock position diagram. Lock is in the direction of the arrow unlock is up see small circle
Jan 04, 2011 | HP Photosmart E217 Digital Camera
Why dose my camera say SD protecetd?
Your SD card is locked meaning is write protected. To unlock it you need to slide the small plastic toggle out of the 'lock' position. See image below
Dec 28, 2010 | Fuji FinePix S7000 Digital Camera
SD card can't be read "Card Locked" is all that
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 27, 2010 | Jazz DV-179 Digital Camera
SD Card Locked; Tried formatting SD card still no luck
There will be a small slide switch on the SD card u need to just slide that switch on the Opposite side that then insert it to the camera it will work fine....... Good Luck
Jan 19, 2009 | Polaroid i830 Digital Camera
Any card LOCKED
If SD card check to see if lock slide is on. Lastly try new memory card, they're cheap nowadays.
Dec 21, 2008 | Canon PowerShot A530 Digital Camera
Card is locked
Try removing the SD card from the camera and slide the lock switch on the side of the card to the unlock position.
Oct 22, 2008 | Canon PowerShot A400 Digital Camera
Memory card is write protected
thought the cards have a little tab on them so they can be "write protected" it is a little plastic tab on the side of the memory1.gif card you slide up and down. I know most SD cards1.gif have it, CF cards dont so if its anything besides SD memory its probobly the memory card or some little switch or somthing in the camera that tells the camera when the card is in the "Locked" or "Write protected" mode.
Looking at my SD memory cards1.gif they have a little arrow on the edge and they say "Lock" pointing down, the slider is up. Move yours both ways, maybe it has a bad connection in the card (im not sure what it actualy does) or its in a position the camera thinks its locked?
Jan 15, 2008 | Nikon Coolpix 4500 Digital Camera
Pentax Optio 43WR Digital Camera Logo
101 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
