Question about Vizio Remote Control XRV1TV 3D - 0980-0306-0921
How do I open a vizio XRV1TV controller to change batteries
How do I change the batteries
My Visio E371vl won't power on with remote. I changed batteries & even bought a universal remote & no power on. the new remote works on other Visio TVs. I can turn the tv on with manual controls.
Dear Anonymous,
  • Unplug the TV for 20 Minutes and plug it back.
  • If that does not work, the remote Sensor on your TV is defective.
  • Take it to a repair shop.
Here is a link to Vizio Support:
Good Luck,
JP
VIZIO Product Support and Services VIZIO
Jul 11, 2015 | Universal Televison & Video
I just purchased a XRT503 vizio remote for my TV and I can'tfigure out how to put the batteries in, no manual came with it
Flip remote over and see if there is a small sliding door on the back that you can slide open for the batteries. Either AA or AAA batteries needed.
Dec 02, 2014 | Vizio Remote Control XRT503 With BLUETOOTH
How to change batteries on VIZIO internet qwerty remote control
Get yourself a thin flat-head screwdriver find the logo on the bottom side of the remote that says "Vizio" You will see the edge of the battery compartment, use your flat-head screwdriver and carefully find that edge, right below the word VIZIO, use your scerwdriver underthe "V" and under the "O" stick your screddriver in and gently push up on these 2 spots till the cover pops, then slowly remove, so you don't break the little parts holding on the cover..
17912129-4302-414a-ac68-bc6289672349.jpg f7d8b044-a3a9-4b77-ba86-c6b7fd71b392.jpg
Jul 03, 2014 | Vizio BRAND Original XRT302 Qwerty dual...
Operators Manual
Try going to www.support.vizio.com or you can contact them on Toll-Free: 877.698.4946 (877 MY VIZIO) http://support.vizio.com/
Mar 18, 2014 | Vizio Remote Control XRT300 XRV1TV...
Vizio remote xrv1tv doesn' t work. it doesn't do nothing. i replaced batteries.what can i do? used to work perfect almost 2 years. do i need to set up the control? how? thanks
Check the remote control for its infrared emission. If found no infrared emission, check its battery compartment, and clean the battery contacts. If battery contacts have been accumulated with dust or dirt, the remote won't work, as there will be no supply to its internal circuit. http://electronicshelponline.blogspot.com/. Check this link. It has one post, that describes how to check and repair a remote control. Pull up older posts there.
May 05, 2013 | Televison & Video
How do i switch from tv to vcr
Just use the AV button on the remote control to select inputs.
Mar 29, 2013 | Vizio XRV1TV Remote Control
Vizio xvr1tv operation
If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Check the site with patience. You'll surely get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 23, 2013 | Vizio XRV1TV Remote Control
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
Oct 25, 2012 | Vizio New Original VO320E Remote Control
My remote control want work
1) change the batteries by new ones
2) clean the contacts batteries with contacts cleaners
3) retight the springs contacts with pliers for good contact
4) open the remote control for clean the keypads switch, from oxide, corrosion, etc for to send good signa infrared to the microcontroller devices(DVD player)
if this not work you must go to the repair shop TV for fix it.
God bless you
Jul 15, 2012 | Vizio VBR120 Player
My vizio remote control stop working changed batteries and it still doesnt work
Take the remote to a Best Buy in your area ( if you have one ) an see if it works on another Vizio set. If it does, then your set will have have to go in for repair.
Nov 19, 2009 | Vizio GV42L 42 in. LCD Television
Vizio Remote Control XRV1TV 3D - 0980-0306-0921 Logo
334 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
