Question about HP Photosmart C7280 Laser Printer
Scanning to computer
I have a C7280 All-in-One.  I have a MacBook.  I am trying to scan item into computer.  I am able to do it using a Flash Drive but not directly.  On page 49 of the instruction booklet, it advises to Press Scan Menu and pick Scan to Computer.  I do not see this on the menu.
Please advise.
The poster down below was exactly right!! I'm just moving the solution up here so more will see...
I'm on a MacBook Pro.... Go into your "HP Scan Pro" and you can direct the scan from there, to be whatever format you want, and to go anywhere on your computer you would like! (Rather than requesting the scan from the panel on the printer)
Posted on Apr 21, 2009
  • 3 Answers
I had the same problem until I set up the various choices using the HP software on the computer. It then saves Scan to Computer as "x" file (your choice). Save your settings in the HP Solutions Setup Center. Then, when you check your printer, they will all be there as choices when you select Scan button.
Posted on Jan 23, 2009
When trying to scan a photo from the c7280 to the computer the printer displays the following error message No Scan Options : refer to documentation and troubleshoot. This is not covered in my printer...
That's because it's not a printer problem. The scan options are in your computer in the scanning software for your machine. Before you can scan you need to be connected to your computer with scan software running to tell it how to scan, what you're scanning, and where to send and save the image you scan.
Apr 20, 2010 | HP Photosmart C7280 Laser Printer
Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Jan 13, 2010 | HP Photosmart C7280 Printer
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Jun 18, 2009 | HP Photosmart C7280 Laser Printer
Can't scan to computer
I am not an expert, only a c7280 user. I use my printer wirelessly and was having problem scanning when using the controls directly on the printer (scan menu). By trial and error, I tried scanning by going to HP solution center on my computer and just followed the directions from the scan menu. That worked. If you can print wirelessly, you can scan wirelessly. I agree the HP support is a huge waste of time. I only get mad talking to them.
Apr 16, 2009 | HP Photosmart C7280 Printer
I cannot scan onto my HP c7280, but I can print to it. It connects via cat5 to switch. I cannot 'locate' the scanner.
check for the scanner drivers in the control panel,if they are there...if not you will have to reinstall the scanner drivers on your computer.use the s/w cd that came with the printer and install it all over again..then try scanning from the windows photo gallery or the MS paint and word.These do not use the twain drivers ,they use the windows scanner drivers....see if it works
Mar 12, 2009 | HP Photosmart C7280 Laser Printer
HP Photosmart C7280 Laser Printer Logo
316 people viewed this question
Seeker5211
Seeker5211
