Question about Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat
Rheem pronto dip switch setting - Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat
3 Suggested Answers
  • 244 Answers
SOURCE: need hi and lo setting for natural gas and correct
Contact Paloma/Rheem customer (800-432-8373) support they can walk you through the process
Posted on Nov 11, 2009
  • 77 Answers
SOURCE: I have a Rheem tankless pronto unit. I had a
is there any type of surge portection for tankless water heaters mother boards??????
Posted on Mar 08, 2010
Can Richmond tankless heater which is now LP be converted to natural gas?
If it can, then it is done with dip switch settings.
Read your product manual.
Switching types of gas, and messing with dip switches is dangerous.
LP gas burns much hotter than NG, and LP pressures are much higher than NG
Call Rheem with serial number and they might supply the information to you, but will likely tell you to call service technician... leaving you in exact same spot you are in now.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
Sep 29, 2014 | Rheem Richmond Encore Tankless LP Gas...
Convert to LP
Often tankless conversion to different gas is done with dip switch settings
Check product manual
Call service technician
Call Rheem
Gene
Aug 22, 2014 | Water Heaters
ARE THERE INSTRUCTIONS
Call Rheem... and they might suggest local technician, or give you correct instructions and dip switch settings if that applies.
Otherwise Rheem does not post service manuals
Gene
Water Heater Timers Save Money
Jun 20, 2014 | Rheem RTG20214D Liquid Propane Commercial...
Rheem RTG53DVP code 82
Before calling service technician, open following link for resources including error codes, Rheem chat and possible manual:
Error codes are considered start-point for troubleshooting, and give service technician direction for isolating problem.
Error 82 appears as 'gas type data failure' > 'Program PC board for proper gas type.'
Gas type is choice between LP gas and NG natural gas.
Gas type programming is controlled with dip switch setting.
I do not have service manual for product, and would not suggest changing dip switches without specific information beforehand.
Aug 16, 2011 | Rheem RTG53DVP Direct Vent Liquid Propane...
Mar 06, 2010 | Rheem Tankless Hot Water Heater...
Only heats water to 1oo degrees and temp on remote is set at 140 ?
I just changed mine today with help from Rheem support as the manual had a typo error.
You should be able to increse to 120 max as default. However if you want to change to 140, you will have to perform the following as detailed in the manual ...
- Turn off the power.
- Remove the cover.
- There is a dip switch on the controller board. Flip dip switch #4 to "ON". Your remotw will start flashing.
- Press SW2 on the controller board for at lease a couple of seconds (The manual states SW1 which is incorrect)
- Flip dip swich #4 back to "OFF"
- close cover
- Turn on heater ... you should be able to adjust up to 140.
Dec 31, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Need hi and lo setting for natural gas and correct sequence to push buttons on Rheem Pronto unit
Oct 09, 2009 | Rheem Tankless Hot Water Heater...
Rheem Pronto Hotwater Heater Error
Unplug unit from wall. Disconnect remote wires from circ board, and let unit set for about 5 minutes. plug back in. run water and see if unit comes on.
Jun 16, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat Logo
23 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
