Question about Pentax *ist DL (W/18-55 LENS) Digital Camera
Pentax Ist DL auto focus not working anymore after using Quantaray AF LD 70-300MM Lens
I borrowed a Pentax mount Quantaray AF LD 70-300mm Tele Lens from a friend of mine and it worked fine, including the autofocus, but when I removed the lens I put my original 18-55 that came with the camera the auto focus stopped working! I tried switching back to the Quantaray only to find out the auto focus no longer worked with it either. The interesting part is that my friend experienced the same problem after using the Quantaray, but thought it was just his camera. Any suggestions? I did upgrade the firmware to 1.03, but this didn't help and also reset the settings without any joy.
  • Anonymous Aug 30, 2008
    Always shots without focusing, even without lens.
  • wolfvinay Feb 11, 2009
    I've also been having the same problem :-( & even I assumed tht I was the only person having this problem
    Genius:
  • 2,985 Answers
It seems to be a connection issue between the Lens and the Camera body. Perhaps the mount is not true to the body Ask Pentax about this their Technical Support Team
Posted on Jul 07, 2007
6ya staff
SOURCE:
Will this lense work with a Canon Rebel T31 ?
Quantaray makes their lenses with a variety of mounts. A lens with a Minolta mount will not fit onto a Canon camera. A lens with a Canon mount will work just fine on a Canon camera.
Dec 09, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Will this lens work with a Canon 5d mkii?
Quantaray makes their lenses with a variety of camera mounts. A lens with a Nikon mount, for example, will not work on a Canon body. As long as you get the lens with a Canon mount, it will work with the 5D MKII.
Mar 09, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Will my Quantaray AF 70-300mm 1:4-5.6 LD TELE-MACRO(1:2) going to work with the Sony Alpha cameras? The A55 in particular?
Quantaray makes lenses with a variety of mounts. A lens with a Nikon mount, for example, will not fit onto a Sony A55. If the lens has the Sony mount then it will work fine with the A55.
May 03, 2011 | Quantaray Cameras
Hi, i have a pentax ISTDL and when i try 2 use it in manual focus the AF still works on its own
Check your lens there is often a AF/MF auto/manual focus switch
Other than that it could be a problem with the camera take it to your dealer
Apr 08, 2011 | Pentax *ist DL (W/18-55 LENS) Digital...
Sigma 70-300mm lens defaults to manual focus
It will default to manual through the viewing screen. It will only work on automatic, using the viewfinder. Make sure you also set the focal length (lens to shutter distance). You might also have a mf / af switch on the lens. This also only works through the viewfinder.
Jan 16, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Quantaray 251664736 compatibility
It depends on the lens mount on the lens itself. Each camera maker uses a different mounting system. In some cases, a camera shop can change the mount on a third party lens like a Quantaray.
If you happen to know the camera that the Quantaray was initially used on, that helps answer your question. A Nikon will not fit on a Canon, will not fit on a Pentax, will not fit on a Sony, etc, etc.
Oct 05, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Cameras compatible with Quantaray AF 70-300mm lens
Depending on how new your Minolta SLR film camera was, the lens may or may not work on a Minolta Digital SLR. In many cases, a lens with the correct mount (in this case, a Minolta mount) can be used on the same brand of camera in the digital format.
One thing you should know is that DSLR sensors are, generally speaking, smaller than the size of a 35mm film negative. Long story short, that means that your lens will have a magnification factor on the DSLR. Usually, it is in the range of 150%, so a 70-300 lens from a film camera would cover 105 to 450 on a Digital SLR.
To be sure about the mount, you'll need to seek advice specific to Minoltas -- probably best to take your lens to a local camera shop and see for sure if it fits and what features will work (aperature, auto-focus, etc) and which won't work on the DSLR.
May 31, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Does a Quantaray Tech-10 75-300 lens fit a Pentax *ist DL digital camera?
Quantaray makes lenses with a variety of mounts. If the lens has a Pentax mount then it will fit onto your camera. If it has a Canon mount, for example, then it will not.
Feb 28, 2009 | Pentax *ist DL Digital Camera
AF problem with Quantaray 2X adapter
How does it stop working? Do you mean it doesn't auto focus anymore?
Many longer focal length lenses wont auto focus with 2x teleconverters on them.
Nov 27, 2007 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Pentax *ist DL (W/18-55 LENS) Digital Camera Logo
449 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
