Question about Sharp Aquos Televison & Video
Sharp Aquos - Netflix sound plays through TV rather than through stereo
I've spent hours doing online searches and reading forums with no success. Getting awesome sound and picture when watching cable or DVD -- the sound routes perfectly through the stereo. I am using HDMI for this. However, when I watch programs coming from the TV such as Netflix, the sound only comes through the TV itself, and is not routed through the Onkyo stereo. I understand about HDMI-ARC, but although my HDMI cable and the Sharp Aquos both supports HDMI-ARC, my Onkyo stereo apparently does not support ARC, so that is a dead end. What are my other options? I've tried plugging a separate HDMI into the TV (in slots HDMI-2, -3, and -4) with the other end plugged into the available HDMI slot to know avail. What else can I try? Can I use HDMI for this at all, and if so, which slots should it plug into on TV and stereo, and what mode should stereo be in to play the sound (I've tried everything)? If HDMI is a no-go, then what are my other options for routing the TV's Netflix sound through the stereo, and if so, again, what slots would the cable go in and what mode would the stereo be set to? Thanks!
  • 1139 Answers
SOURCE: Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83
Posted on Jun 10, 2009
SOURCE: hdmi 2 wont work on mitsubishi wd-y65
It sounds similiar to a problem we've had with ours, all components would work in hdmi 1, but hdmi 2 would only work intermitently. They ended up replacing the digital board (fortunately we have the extended warrenty, I'm sure it's not cheap). Sorry hope this helps.
Posted on Feb 23, 2010
  • 20 Answers
SOURCE: HDMI input says "mode not compatible"
If your Playstation is putting out the signal in 1080p then try changing it to 1080i and see if that works. Not all TVs are compatible with 1080p.
Posted on Aug 02, 2012
Testimonial: "Don't know how I never considered that the PS3 output settings would have been the problem. I was so fixated on the TV settings that I completely overlooked the PS3 setup! That was outstanding advice!"
SD Tech
  • 14553 Answers
SOURCE: Tv says "Not supported mode." when I plug Hdmi cables into the back slots. For both component 1 and component 2. What does that mean?
What are you connecting? Also note that HDMI does not "like" to be connected with units powered up or on---
Posted on Dec 17, 2012
  • 760 Answers
SOURCE: Can't connect Panasonic Viera TV to PC with HDMI
Check your owners manual. Some TV's will not except PC resolutions.
Posted on Mar 20, 2013
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Why is my 2011 Sharp Aquos TV crashing?
Sharp Aquos "crashing" - HDTV - Streaming Video & TVs - Tom's Guide
Aug 11, 2005 - 7 posts - ‎1 author Archived from groups: (More info?) I have a Sharp Aquos 37" LCD TV(37GD6U). Every now and then I can turn it on,
Oct 20, 2015 | Sharp Televison & Video
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like, to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Will not read disc
As it's less than a year old the manufacturer's warranty should still apply.
Your player probably has a failed laser head unit; if you have to pay to fix this fault then you'd be better off just chucking it away and buying a replacement as it will be cheaper.
Mar 15, 2010 | Sharp AQUOS Blu-ray Disc Player
Sharp Aquos LC-32GH5 and MacBook problem, HELP! I've recently bought a 32" Aquos and want to use it with my MacBook as a secondary monitor and screen for movies, etc... I bought all...
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
Aug 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Mono sound only
I have an LC42D64U with firmware U0709111. This is an 11 month old unit. It was working fine until I lost power one day, then I couldn't get any sound. It always showed up as Audio: mono. I tried every setting and nothing (although XBOX via HDMI still played though the onboard audio, so I knew it wasn't a HW issue).
After searching around for a method to change the mono/stereo I resorted to the Fred Flintstone's fix and simply pulled the plug on it. Immediately after turning it back on it worked.
This is hardly a fix but it worked for me.
Nov 20, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
126 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
