Question about Kenwood KDC-128 CD Player
:I shorted out my kdc 128 head unit and i switched all the fuses but it still wont turn on. any ideas?
I have a kenwood KDC 128 cd player. i connected all the wires and plugged the wire harness into my truck, the radio lit up and everything worked. i then took it out and sautered all the connections and put it back in the dash. when i turned the truck on, i noticed a spark and saw a spark and the radio shut off and i realized one of the wires had grounded itself on the in dash harness. i took it out and taped all the connections with electrical tape, put the radio back in and now it wont turn on. i checked the fuse in the back of the radio and the fuse in the fuse box and neither was blown. any one have any answers as to how to get it working again? i also took the radio apart and looked at the circuit board and nothing was black or appeared burnt.
    President:
  • 720 Answers
Firstly, the main wires from the KDC-128 you need to check are:
RED - this should be connected to the vehicle's +12v IGNITION wire.
YELLOW - this should be connected to the vehicle's =12v BATTERY wire.
EARTH - i) some tuners will only earth when the tuner itself, is screwed into the vehicle's chassis (i.e. a metal mounting bracket); ii) some tuners require the BLACK wire to be attached to the vehicle's chassis (i.e. a metal mounting bracket).
Secondly, if the above wires are connected correctly, then you should suspect the fuse on rear of the tuner has blown (even if it LOOKS ok). Replace and see what happens.
Thirdly, if all above are ok, then you have a short somewhere on the vehicle.
Posted on Mar 14, 2013
3 Suggested Answers
MrLard
  • 94 Answers
SOURCE: KDC 128 CD Player
It could be that the player is going into protect mode. This is normally due to a short in a speaker cable, or one or more of your speakers is blown. Try disconnecting all of your speaker cables at the speaker end and make sure the connectors don't touch. Power it up again and see if it stays on. Bear in mind you won't hear anything. If it powers up. Carefully plug each speaker back in. It will power off if you plug in the dud! If it still doesn't power up. disconnect all of your speaker cables at the player end. If it powers up this time one of your cables is shorted. Same as the speakers, plug one pair of wires in at a time to find the dud. If it's still switching off. It could be a blown circuit on the output stage of the amp. Here's a silly question. Does the player get hot? All this assumes that you have had this player working with these cables and speakers before. If not check that the speakers are the correct rating (Resistance in Ohms) for the player. And lastly here's where you can get a manual http://www.kenwoodusa.com/Support/Car_Files/#_
Posted on Sep 10, 2007
  • 12 Answers
SOURCE: Got a new Kenwood KDC-128
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Posted on Jan 02, 2009
KDC-MP4032 head unit wont turn on
hi, seeing that your kenwood showed up "protect" you may have an audio circuit/amplifier fault within the unit. try resetting the unit to see if unit comes "on" again. if the unit comes on and protect flashes again, then you definitely have an internal audio circuit fault. if not then check all power connections(yellow and red wire voltages, as well as ground connection), as well as the condition of the face pins!
May 31, 2012 | Kenwood KDC-MP4032 CD Player
Can get kenwood kcd 128 to turn on
ok black is ground, red is remote, yellow is battery, orange is illumination, make sure the antenna wire is in and you hold down the SRC button for about 3 to 5 seconds. please vote.
Jul 29, 2010 | Kenwood KDC-128 CD Player
I want to hard wire (not using any kind of wireless gadget) my ipod in to my car to the Kenwood KDC 334 CD player which is installed. I have pulled the Kenwood unit out and there is no obvious connection,...
The KDC 334 doesn't have any audio input, so there's nowhere to hardwire an iPod or other mp3 player into the unit.
I'm sorry, but the only way to get iPod sound to come through this head unit is with a wireless gadget like the iTip FM adaptor.
Feb 18, 2010 | Kenwood KDC-334SA CD Player
Ineed a manual user guide Kenwood kdc 128 cr
You can get your manual here:
http://audio.manualsonline.com/manuals/mfg/kenwood/kdc-128.html
Nov 23, 2009 | Kenwood KDC-128 CD Player
Kenwood head unit not powering up help please.
find your remote wire. it would help to know the type of car and the kind colors of wires your using as your 3 main wires.
normally in most chevy and fords they are yellow 12 volt.
black as ground.
red sometimes even a tan as your remote start.
deff check your start
May 09, 2009 | Kenwood KDC-W6027 CD Player
I hooked up my kenwood kdc 128 cd player and nothing works
i had the same problem as you, i own a 98 ford escort, and i couldnt find a wiring diagram that matched the ones in my car . i managed to connect the constant (red) and switched (yellow) to the wires in the car but i had made a mistake with the ground (black) . so i re connected it to where its suppose to go so now the head unit actually lights up and turns on.
now i have another problem because my head unit doesnt stay on for any longer than 1 mintute
Mar 05, 2009 | Kenwood KDC-128 CD Player
Got a new Kenwood KDC-128 car radio recently, fitted it but the radio presets would not stay when the ignition was turned off. Then it stopped working altogether and I noticed the 10amp fuse at the back...
Jan 02, 2009 | Kenwood KDC-128 CD Player
Head unit problem
Hi John Steel
Try disconnecting it from all 12 volt sources(overnight)to reset the code entry procedure. If that dont sort it, let me know and we shall try something else
regards
robotek
May 21, 2008 | Kenwood KDC-MP228 CD Player
Kenwood cutting out
rewire the radio strait to your battery that will make share that you wont make a short
craig:)
Jan 15, 2008 | Kenwood KDC-MP228 CD Player
KDC 128 CD Player
Sep 09, 2007 | Kenwood KDC-128 CD Player
Kenwood KDC-128 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
