Question about Yaesu FT-711RH Technical Suppliment
FT 711RH, Radio gets very hot in receice mode, and will not show power output when mic in keyed
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
To get a reading of your radios RF ouput, requires a dummy load test.
I somehow doubt that this is causing the heating of your radio.
All large radios, as yours is, have a built in heat sink, with a fan usually installed, depending on the model and output wattage of the transmitter unit.
The fact you say it gets very hot, indicates that the fan may be the culprit, and will need cleaning and/or replacement.
I hope this is helpful to you. Anything else you need to know about your radio should be directed here: join yahoo group SPECIFIC to your radio Make/Model, there you will get expert advice and info, also you can download manuals, diagrams and software for you radio.
You have a great radio, look after it and it will give you many hours of enjoyment.
Kind regards,
Peter
Posted on Mar 05, 2013
3 Suggested Answers
WV6Z
  • 7 Answers
SOURCE: FT-920: When the TUNER switch is pressed, the
Have you tired performing a general reset (see page 92 of your Operator's Manual). If you have tried this and still have had no luck, be sure that you have established a good ground to earth and that you are not getting a lot of RF back into your 920.
If you do not have a manual for your rig, one can be downloaded here http://www.download.n7tgb.net/yaesu/FT920/man_ft-920.pdf
You can also call Yaesu Tech Support for free/additional help at 714-827-7600, or join the Yahoo FT-920 User's Group at http://groups.yahoo.com/group/YaesuFT920/
Hope this helps......
Posted on Jun 26, 2009
SOURCE: My Yaesu ft-100 has a problem on the UHF band.
You have probably a faulty VHF/UHF relay. It is RL5016 in LPF unit.
73 JOSE EB5AGV
Posted on Jun 09, 2010
Ft 2900r when I push then talk button on mic it shows error on all channels even with second mic
Sounds like a programming error. Does it work properly in VFO mode? Did you try a reset?
Jan 10, 2015 | Yaesu Ft 2900r Vhf Mobile 75 W Two Way...
Why does the unit does not seam to work on SSB?
Since everything else works then is it USB or LSB or both? Did you check the power output when your in SSB and if there isn't any you can expect the drive transistors. Try putting the radio into the RTTY or CW mode and see if there is any power output when you key the mike PTT.
Good luck,
73's Marty
Jun 19, 2014 | Icom IC-7100 Mobile radio, HF/6m/2m/70cm,...
I have a kenwood ts690s not transmitting full power
AM will only give to about 40W without modulation. This is the RF Carrier required for the AM Mode. This is because the RF Carrier is modulated by your voice, and when speaking into the mic, the voice peaks will increase the output to about 80W if not measured with a peak reading wattmeter. All radios will work like this in AM.
SSB requires audio to get any RF output. If your microphone is defective, or your MIC GAIN control is fully counter clockwise, you will get no output power when you speak into the mic. Output power, if not measured with a peak reading wattmeter will bounce to about 80W on voice peaks.
MOST wattmeters are not peak reading.
Apr 01, 2014 | Kenwood Radio Communications
My cobra 142 gtl loses power about two minutes after keying the mic.
hi
it looks like the output stage is going hot (99%)
maby the swr is high end eficiancy is low
usualy on ssb the power is higher than on am
bernard
http://www.rylwy.com/
Aug 03, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
My radio shows power but its not transmitting out and shows only5 watts on a meter
Don't rely on that meter. use a good Known external meter to check.. make sure your mode switch is on am... not any other mode. also try a different mic. New mics start --RK56's$38.99/Stock mics$6.99...
Mar 07, 2011 | Galaxy Radios DX-95T Base CB Radio
Cobra 18 wx st receives-wont transmit
Take the cover off, flip it over solder side up, check all solder joints for cracks, cold solder joints, check the safety diode where it comes in the radio, before I go further, can you pick up the weather channel?...Does the PA work?...need to check the pre-driver and finals,audio chip, hook up the power meter using a coax three foot jumper from the output from radio to the input of the watt meter, then the antenna, first check the SWR, on the scale on the meter to cal/swr mode,adjust it to spec, then while still keyed down turn the dial to SWR,if it is the safe range your ok,then turn the Dial to 10 or 20 watt scale and key the mic. Does it have any wattage? If not suspect the finals, they are located on the back rail, if it does have RF then its the audio chip, its located on the right side rail facing you,closest to you.remove it and replace it with same ....hope this helps....
May 21, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
C.b.radio-power won't come on.(red & black wire show short!)
The fault is probably at either end. Yes, it could have been reversed, but most radios are easily protected against this.
If you are getting no lights or anything when keying mic, then there may be an inline fuse along the cable. As you are getting continuity, open the case up, and look for any evidence of heat at the components nearest the power supply - particularly the protection diodes - Black cylinrical components with a silver band.
You really need a meter or scope to go in much further, and check supply voltages between components and -ve, and downloading a copy of the circuit diagram will help this.
The other main fault is usually the output power transistor - which needs a sink for all the power getting thrown at it. If you remove the antenna, it can quickly overheat and fail.
Both components can be checked in-situ for voltage (or not) but the output can only be tested with a scope.
Of course - the "on" light could have blown, so may be functioning without indications, - but I doubt it.
Also check Mic outputs on the plug to make sure that is working. Some units won't function if this is disconnected.
Jan 08, 2009 | Cobra 29 LTD CB Radio
10 kc drop at key up no transmit
have you changed the voltage regulaor, or check it first 2 outside legs should red your 13 volt middle around 9
Jan 03, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Cobra gtl 148 seems to have no power til i push on mic connecter.
cobra 148 shows no wattage output on external meter but does show good modulation.
Dec 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Yaesu FT-711RH Technical Suppliment Logo
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
