Question about Bowflex Tc5000 Climber Treadclimber Treadmill Bow Flex Tread Climber Tc-5000
Why does my Tc5300 stop after three minutes and shows an error report
Tc5300 stops after three minutes and shows an error on the console
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
My xbox ix switching on and shows three red rings and after 5 minutes the brick turn orange and it now has two red rings whay do i do to fix it
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
Jan 10, 2013 | Microsoft Xbox 360 Console
My friend has a sega dreamcast which turns on, shows the menu, but then turns off after only 10 seconds. I've seen reports of a dreamcast turning off during game play, but they all say it's 15-30...
Most likely it is over heating due to a fan that stop spinning or dust in the vents. Make sure the fan is still working and clean it out with compressed air.
Here is a great site all about repairing it - http://www.ifixit.com/Device/Sega_Dreamcast
May 06, 2011 | Sega Dreamcast Console
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
We just spent the last 3 hrs putting our Bowflex Treadclimber TC5300 together only to not be able to start it. We cant get past the screen that says insert e-stop magnet. Of course we inserted the magnet...
HI check the magnet socket is clear and clean , check magnet and wire and clip of any damage . you can try and put a magnet in the socket this should make it start . Don't throw it out , its a great machine I have one love it the works outs are very good not easy . Hope this helps
Jan 29, 2018 | Bowflex Treadclimber TC5300
How do I delete the error reporting to microsoft
if it is Showing ” Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience ” Click “Don’t Send ” and everything get closed ,This Window error Report generated by microsoft is sometimes create problems for you , it is suggested you to dont ever click Send Error Reports or ” Please tell Microsoft about this problem ” because it will send all yours computer details to Microsoft , and creating problems for you.so its better to disable that error repor,so that such problem not arise in future,There are three methods to disable Microsoft error reporting.
  • To get rid of this MS Error Reporting, Right-click the My Computer icon on your desktop and choose Properties.
  • In the System Properties , go to the Advanced tab and click Error Reporting.
  • Select disable error reporting This will make any crashing program’s window simply close itself.
  • You could also click But Notify Me When Critical Errors Occur, but it might be even safer if you select Enable Error Reporting.
Inspite of this technique you can also disable error reporting via control panel as well as via editing registry . icon_smile.gif
Tags: Dont Send, Error Reports, Microsoft, Window Error
May 19, 2010 | Computers & Internet
E74 error code for xbox
The E74 error is caused by the scaler chip at the back of the console taking too much heat. To fix it you need to stop the heat build up.
You can do this yourself using a good guide that will show you how to fix it with household items or you can send it in and they will fix it for you.
Feb 02, 2010 | Microsoft Xbox 360 Console
Disc Error
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide....
Apr 07, 2009 | Nintendo Wii Console
Hammer voltage 2
it prints for about two minutes then starts slowing down and then stops printing showing an error of : hammer voltage 2
Sep 05, 2007 | Tally T6218 Matrix Printer
Dryer shows f44 error
007, F44 is a motor control electronic failure. Couple of things you can try. 1. Unplug the dryer for 1 minute. Plug it back in and see if the error stops. 2. Under the consol there is a 3 wire harness that runs between the two control boards. Try reseating this harness. If that doesn't work, you will either have to call for service or do some detailed trouble shooting. Catriver, post back.
Aug 17, 2007 | Kenmore 67082 Electric Dryer
Bowflex Tc5000 Climber Treadclimber Treadmill Bow Flex Tread Climber Tc-5000 Logo
24 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
