Question about Texas Instruments TI-5045 SVC Calculator
How do you put a roll of paper in?
I just got this with no instructions. I can't figure out how to add the roll.
Thank you very much.
  • doris32 Feb 02, 2009
    same problem
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
See the illustrations on page iii of the manual: http://education.ti.com/guidebooks/printer/5033sv/5033sv.pdf
Posted on Jun 27, 2013
I cannot get the calculator canon MP121-DH to print on the paper roll. Any suggestions
This paper will only print on one side. Try flipping the roll over so that it tries to print on the opposite side.
Oct 29, 2014 | Office Equipment & Supplies
How do I program to add taxeshow do I insert paper
You may download a copy of the manual here. The tax instructions are in the second column of the first page, the illustrated paper insertion instructions are in the second column of the third page.
Mar 09, 2013 | Canon P23-DHV Calculator
How to fix a paper feed error
To fix your paper feeder follow the mention tecnique:
1. open your printer paper feeder
2.put off spring
3. Then find out a white roll gide and open it.
4. Open roll gide from the printer. Then open black roll from white case. In the hole a spring apear . put off the spring from there.
5.Finaly assembel all the parts again without the spring.
I think your printer may work again. Thank you.
Aug 24, 2010 | Epson Stylus CX4800 All-In-One InkJet...
How to insert receipt paper
See the illustrated instructions on the first page of this manual.
Jun 18, 2010 | Sharp EL-1197P Calculator
Loading paper
I know this product and I have serviced it before.
I am a retired Xerox Service Representative.
Can you give me more details about this area.
I am not familiar, "by a roll of paper."
This machine can be fitted with one or two paper trays and has a by-pass feed tray, and a document feeder.
I do not know of roll paper that can be fed in this machine.
Thank you, I ook forward in hearing from you to resove this problem.
Mar 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Can't figure out where to put new carbon rolls
Here you go on page 14 it will tell yoi how to change.
http://www.sharpusa.com/files/fax_man_uxp100.pdf
Good Luck and Please Rate FixYa!
Jan 18, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Loading paper
Follow the illustrated instructions on the first page of this manual.
Jul 18, 2008 | Sharp EL-1197PIII Calculator
Ribbon installation
I searched this online, and have found the following instructions:
1) Set the power switch to OFF
2) Remove the printer cover
3) Remove the ink roller by turning it counterclockwise and pulling it upward.
4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
5) Put back the printer cover.
May 30, 2008 | Sharp EL-1801P Calculator
Cannot Laod the paper
1. The end of the paper roll can be cut on either a straight-edge or angled slant. 2. Remove the top cover of the calculator. 3. Insert the paper into the narrow back slit on the back of the calculator so that it feeds under the black plastic plate. The slit is located on the outside of calculator. 4. Use the Paper FEED button to advance the paper up. 5. Replace the cover and feed the paper through the cover opening. Hope this helps. Slit for paper is not immediately obvious, so don't put yourself down.
Feb 19, 2007 | Canon P23-DHV Calculator
Texas Instruments TI-5045 SVC Calculator Logo
90 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
