Question about Mitsubishi WS48511 48" Rear Projection Television
Bouncing Picture on WS48511 MITSUBISHI PROJECTION TV
We have had this TV for several years and have no problems except recently. It first started when we would turn the tv on and the picture would bounce a lot, until about 30 or 40 minutes and then it would be fine. Someone told us to leave the tv on because that was a problem with the projection tv's. So we have been leaving the tv on but turning off the satellite when we turn the satellite back on it's starts the bouncing again and it can take up to two or three hours for it to stop. Sometimes we don't turn neither one off and the bouncing starts. Does anyone know what this might be and how much it costs to repair? thanks.
  • Anonymous May 09, 2008
    my screen bounces
  • 398 Answers
I have seen this symptom a lot recently. There is a 9 volt regulator on the small signal board, and the output voltage on this IC has dropped down to about 8 volts, which causes that symptom. Replacing that regulator should cure your problem, and when I make a housecall for a set like that I charge $150, although I hear that the average service center charges a lot more than that. I also believe that it is never a good idea to leave a projection TV on all the time, so whoever told you that has no idea what they are talking about.
Posted on Jul 06, 2007
How do i fix the convergence on my 48 ws mitsubishi tv? the red will not converge and is jumpy
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
Hi i have a mitsubishi ws48511 that the color
Normaly one colour tubes has problems , the others have opposite sintoms, better is go to repair store for checkup
Nov 29, 2009 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi ws48511 ghosting problem
You need to have the convergence output IC's replaced. These are large amplifiers which control where the red, green and blue beams land on the picture. When they fail you will get colored ghosts. This is a very common problem for any projection television. Any reputable tv repair shop can do the repair in your home and the average cost of the repair is between $225 and $325.
Jun 01, 2009 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Color convergence problem
If you follow the instructions on the other thread, you should be able to resolve the problem. Try the simple stuff first. Resolder the pins of the convergence ICs and see if that alone resolves the problem. Sometimes that is all it takes.
Keep us posted.
Dan
Jan 30, 2009 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi VS-1561
Sounds like you need to clean the lenses and reflective area inside your set. It is easy and all you need is a screwdriver, windex and a paper towel. UNPLUG YOUR TV.   Take off your screen and screen protector and safely set them aside.
Clean only the lenses ( glass part) and the reflective mirror type area on the top of the inside of your set.  It will look like new. You need to do this at least once a year.
Jan 05, 2009 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi Rear Projection 65" tv picture becomes blurred bouncing right to left and color is red & green. TV is 8 years old approx. Any suggestions. Have not had any problems prevoiusly. First it woudl...
Sounds like possible solder connections on the convergence ICs. If so, you will see the red, green, and blue not lining up on ever input and even the mits menu. If you can bump it to correct, its just a solder connection, but if its out all the time then the ICs need replaced. This is a difficult repair only recommended for skilled technicians (40 solder connections + possible re-alignment needed)
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Over scanning
These are good sets, but now the only way to get info is to search the threads here for your problem, and you may find it or you can pay the 9.95 and your problem will be solved and you can rated as that! Still its much cheaper than calling a repairman!
Oct 03, 2007 | Mitsubishi WS48511 48" Rear Projection...
Rear Projection TV
high humidity could be a cause i have a similar problem with a sony rear projection. on some warm rainy days /try cleaning lenses with a photographic anti fog cloth.but be very carefull not to scratch or leave dust on lens.
May 08, 2007 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi WS48511 48" Rear Projection Television Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
