Question about Canon imageRUNNER 210S Copier
Hi i have canon ir 2018 machine with duplex but it dosent giving back to back print
    Problem Solver:
  • 21 Answers
Dupex is an optional item for this unit, fixed on right door and 1 wire harness to be attached with main unit which usually forget please check.
Posted on Dec 20, 2013
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Posted on Apr 20, 2009
SOURCE: canon IR C3220 cannot print multiple pages..ONLY able to print one page
I had same problem with my Canon pixma ip4600 and 4300, it works fine on one of my laptop that has XP but will only print one copy at a time on my laptop with Vista. After a long time playing around with it I found if i set the printer setting range to print pages 1 to 1 ( or 1 to "number of pages in doc"), then put in how many copys you want and click collate.
It worked for me so hope this helps :)
Posted on Oct 11, 2009
iservice
  • 318 Answers
SOURCE: where is the waste cartridge for the canon ir 2018
If you open the front cover and release the leaver of the drum unit.Remove the drum unit.On the drum itself is a plastic plug,remove the plastic plug and remove the waste toner in to a bin.The waste toner is stored behind the drum and must be removed reguarly.
Posted on Dec 15, 2009
  • 6 Answers
SOURCE: canon IR 2018 system error E007
E007 means that the fuser film inside the Fuser unit is damaged which needs to be replaced, or the white patch on the fuser film is dirty and it just needs to be cleaned. I recommend getting a canon technician to fix it,
Posted on Jun 01, 2010
hamzaskilltd
  • 316 Answers
SOURCE: error e-261
zero cross signal error
Posted on Jun 12, 2010
SYSTEM ERROR E007 ON CANON iR2018
Call to 1-800-243-0019 Canon ir 2018 system error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film.
Apr 15, 2017 | Canon Office Equipment & Supplies
Blank printing ir 2018 n
There can be several reasons for your printer is printing blank pages. To help you troubleshoot the issue, please follow the link given below and follow the instructions mentioned on it:
http://canoncanada.custhelp.com/app/answers/detail/a_id/2182/~/printing-blank-pages
GuruAid.com
Jul 20, 2016 | Canon ImageRUNNER 2018 Copier : 2018...
Canon ir 2018 image is lighter than darker
Hi there, I assume when you print that you would like the image to be darker? or is it when you copy?
Aug 07, 2013 | Office Equipment & Supplies
I have been using Canon IR 2018, it shows an error message "System error e007" while copying or printing though its good with scanning.....kindly suggest me some proper remedy to come over....
there is a one white patch sensor on the fixing film, if this patch sensonsor can't read by fixing unit. machines will show E007 error because of fixing film broken.
so you requie to replace fixing film.
May 10, 2011 | Canon iR 2016i Black and White Copier
We are haveing canon ir 2018 it is giveing very light print. if improve the drack ness also it doing like that only
it is possible that the scanner lense for the laser has become dirty, normally if you remove the print cartridge (Tonerand drum assy) you can see a small strip of glass, this can collect toner and dust causing the lazer not to charge the drum and give you bad or light prints
hope this helps
Feb 08, 2011 | Office Equipment & Supplies
My canon IR 2018 copier is giving me system error 007
hi;
its a fixing film problem, your fixing film is not spining properly maybe its paper jammed inside try to clean paper jam carefully else you order new fixing film from canon
good luck
Oct 20, 2010 | Canon iR 2016i Black and White Copier
Hi Sir! We have in the school a IR2020. It work good. 1. How can I set the double site printing from computer? 2. How can I scanning. thx.
Double side printing is possible if you have duplex unit insstalled.Do you have duplex unit?
Under printer properties there must be page setup, where you say that you want to print double sided.
You can scan over ScanGear software. Do you have it? If not you can download it from canon official site.
But it works only as PULL scanner.
Jun 09, 2010 | Canon iR 2020i Laser Printer
Plz send me (detail) feachar of cannon 6050 & cannon 400s on this address CHECHANI TELECOM & PHOTO COPIERS C-278, R.K.COLONY,NEAR CHOTI PULIYA, BHILWARA,(RAJ)311001 +919829045797 +919413824797
CANON IR 6050 IS AN ANALOG COPIER.
CANON IR 400 IS A DIGITAL COPIER.IR 400 IS SINGLE SCAN & MULTI PRINTS ,STACKLESS DUPLEX & ITS CAN BE USE PRINTER & FAX ALSO.
FOR MORE DETAILS VISIT WWW.CANON.COM
Mar 15, 2009 | Canon imageRUNNER 400S Copier
Problem in Canon Laser Shot LBP 3300
Their is Button in the rear of the printer a Blue jack push it inside for duplexing LGL /LTR size paper and pull outside for duplexing A4 size its easy
Dec 01, 2007 | Canon LASER SHOT LBP 3300 Printer
Canon imageRUNNER 210S Copier Logo
old marine
old marine
