Question about Beyond Micro Mobile / 250GB / 7200 / 8MB / Black / USB 2.0 / External 250 GB Hard Drive
Need A Driver For Beyond Micro Mobile Disk External Data Storage Model No.: HD-337-U2C driver
2 Suggested Answers
lock123
  • 6831 Answers
SOURCE: I can't access data off my portable hard drive (model HD-337-U2C)
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Mobile Disc model HD-337-U2P. Where can I get the software and drivers?
Hi!
You can find the original drivers for this drive on the manufacturer's website, here:
Chronos HD 337 U2 Driver New Win All
Hope this helps!
Mar 11, 2016 | Beyond Micro Computers & Internet
WHAT VOLTAGE POWERS THIS UNIT
(Model: DVS-120A15FUS
Input: 100-240V ~ 50/60Hz 0.7A)
Output is +12V, 1.5 A
found this on another forum, hope this helps..
Jun 09, 2012 | Computers & Internet
Problem with the Mobile Disk External Data Storage Enclosure model HD-338-COMP for my 80gb Western Digital HD
just a suggestion but a few years ago is aeons in tech time maybe, just maybe the drivers for that ext drive were overlapped with OS X migration?
check apple site for more or ext drive site for latest drivers
Jun 02, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Hi:I have a Beyond Micro, model HD 337 U2C. Suddenly after no problems I can't access about 3/4 of the content of the hard drive. It sounds OK , but just is not functioning. If you can't fix the...
if you can access your beyond micro hard drive
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select
check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Feb 05, 2011 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I got an external driver with one side Mobile Disk and other side hd-337-combo can somebody help me to find the drivers cause i tested the hard disk in my PC and with the mobile disk my pc says USB Device...
Mobile Labs provides enterprise-grade, next generation mobile application testing tools. With a focus on security, agility and affordability, Mobile Labs delivers solutions to help you deliver quality mobile apps for Android, iOS and Windows platforms while also helping manage mobile devices in a private, secure cloud.
Mobile Device Testing Mobile App Testing Mobile Labs Inc
Jun 07, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Hello
Kind Regards
Andrea
Mar 01, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Drivers
The only DRiver is already supplied with OS 2000pro & up as Firewire. Problem connecting is due to the Supplied Power Supply. Wattage is too low at 1.5. Try a higher Power Supply.
Nov 14, 2008 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Beyond Micro Mobile / 250GB / 7200 / 8MB / Black / USB 2.0 / External 250 GB Hard Drive Logo
82 people viewed this question
Top Beyond Micro Computers & Internet Experts
David Payne
David Payne
Are you a Beyond Micro Computer and Internet Expert? Answer questions, earn points and help others
