My c840 latitude wnt boot with my previous power adpt you need to push f1 to start it
  • 38 Answers
Hello. That is because your computer measures the voltage from your power adapter. if the power is incorrect, then it will make you press f1 to adjust the computer to accept the power adapter. You need to get the correct adapter for the problem to go away. good luck !
Posted on Sep 08, 2009
CAN A DELL LATITUDE C840 BE BOOTED FROM ITS USB
power laptop on then pressing F12 and the Boot Device Menu appears
if usb is not an option on the list you cannot do it
Jan 27, 2014 | Dell Latitude C840 Notebook
Need to reset cmos for booting to DVD drive dell latitude c840
Hi try pressing the ESC button during boot up, sometimes its the delete button, then select this drive by scrolling down, select CD drive for primary boot device, save changes and reboot. Hope this helps, come back to me if you need more help?
Jul 07, 2010 | Dell Latitude C840 Notebook
What is extend ram capacity
There are a lot of reasons your laptop is not accepting the new memmories
1) If it is an old laptop the motherboard might not support upto 1 GB of memmory
2) It can also be due to the fact that the connections are loose and the ram is not properly inserted or dust is interfering the contact
3)It can also be due to the difference in frequency and latency of the new ram you inserted
4)it can also happen when the frequency of the ram exceeds the frequency supported by the Front Side Bus(FSB)re it is compatible and also ensure that it is properly fixed
Check the ram ratings and make su
May 28, 2010 | Dell Latitude C840 Notebook
Has 1Gb Ram installed. Bios not recognizing dimm
was it new ram you bought or was it out of some other machine because it might be a caes of bad ram. try your old ram in the laptop and see if it boots up if so then get your ram chaged.
Mar 14, 2010 | Dell Latitude C840 Notebook
How to turn my wifi on on my dell latitude c840?
most dell laptops you hold the FN and F1 button down the outher way is go into Network Connections right click on the wireless and then enable hope this works.
Dec 29, 2009 | Dell Latitude C840 Notebook
My Dell C840 Latitude has a 1.8Ghz processer but when I checked system it says it's only running 789 Mhz. Is my processer going bad?
Go Into Control Panel, select Power Options, and change Power Scheme from Laptop/Laptop to Home/Office Desk. Make sure you have AC Adapter plugged in and your should now be using all of CPU. Check System icon from Control Panel to confirm. CPU usage may show as less when laptop is booted from battery power only.
Dec 04, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
C840 will not boot up
Quick power off means a hardware fault. Remove the memory sticks and boot the laptop. If you get an error message, the memory sticks are bad. Replace them. If it still doesn't boot to BIOS, your motherboard has failed and needs to be replaced. It can't be "repaired" cost-effectively. And since the Inspiron C840 is a very old laptop, probably not worth fixing. You CAN get your data off the hard drive by slaving it to another computer. Google " hooking up an external hard drive".
Feb 05, 2018 | Dell Inspiron 8200 Latitude C840 Laptop...
Windows will not start
try reseating the hard drive. Unscrew two screws on bottom right of laptop, where it IR window is. Slide the cover down, then out. Make sure the bottom connector is flush, then slide it back in
Jun 17, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
