Question about Dell G2210 22 inch LCD Monitor
Dell G2210 has horizontal lines on entire screen the pattern of the lines changes each time you turn it on and off but eventually go back to just the grey horizontal lines
3 Suggested Answers
SOURCE: Display goes black after 5 minutes
Repairing the DELL E171Fpc LCD Monitor with the complaint of display shutdown after few seconds (power LED still on) was not difficult. Normally when this type of problem happens, we would first suspect the inverter board, then the filter capacitors and lastly the main board. A defective in one of the lamps and a faulty TL1451AC PWM IC or inverter ic may caused the display to shutdown as well. If the lamp is defective, it will send a feedback to pin 3 or 14 of TL1451AC IC and caused it to stop producing output signal thus the display just shut off once you switch it on.
Posted on Jun 02, 2007
  • 2841 Answers
SOURCE: I'm using the laptop with
Let it go ahead and enter Safe Mode. Then restart the computer and it will start normally.
Posted on May 23, 2011
Dell Inspiron 2350 All-in-One Desktop PC Fault Flickering Touch Screen
It could be 1 of 2 things, either your monitor is going out on you, or your graphics adapter is going bad. Depending on how long ago you purchased it, and from whom, I would contact Dell service to find out if they can return it, or give you any suggestion.
May 19, 2014 | Dell Computers & Internet
73' Mitsubishi has magenta splotches moving around screen and eventually getting larger until whole screen is covered.
bad main digital board. It's the bottom board on the left, try Encompas Parts to get digital board.
Nov 27, 2011 | Televison & Video
Hi, I have a Dell Precision M90. It has worked great until now. The problem started when I walked away while it was turned on. It was not on my docking station. When I came back a while later the screen...
these problem called garbaig problem
first of all plug out your pc ram and rub its golden area from a rubber
if the problem is still then replace it with the new one.
if problem not solved yet its mean your ram is ok and problem is in AGP now you have to change your agp. ok
Jul 18, 2011 | Dell Precision M90 Notebook
My Dell monitor developed a thin, dark line horizontally across the screen. Within three months, a second line appeared. I can view the screen, but must look above or below the lines at times. Any idea...
this occurs very commonly in all LCD monitors... this is because each and every cells in the LCD monitor are energized by the vertical and horizontal electric fields placed around the frame of the monitor... if a particular field does not gives the power to the associated cells to it, then the entire line of cells will not operate and together they looks like a single line...This is what happened in your case...
have a look at my tips for replacing the LCD screens on monitors, by clicking here....
Aug 11, 2010 | Dell Audio Players & Recorders
Dell E176FP Monitor Stuck in diagnostic mode??
See if the set has some sort of reset button. If none do a hard reset on monitor to hopefully clear the cobwebs in monitor electronics and see what happens.
Mar 12, 2017 | Dell E176FP 17" LCD Monitor
Bottom of screen flickers, and eventually the screen 'freezes'
they have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
Jan 17, 2009 | Prima CV2011 TV
Dell Axim problem
Most likely a bad connection along the sides of the screen causing a line of "dead" pixels. I have a similar problem with an old GPS reciever (several lines). You could attempt to repair but that would be risky unless you purchased a new working screen and replaed the entire screen (can find on ebay at times)
Apr 28, 2008 | Dell Axim X5 Pocket PC
Toshiba Satelite A105S2617 Power Problem
Hey buy dell laptop. they have some gud warrenty options. They replace hardware for free upto 4 years max if they are faulty.
Dec 20, 2007 | Toshiba Satellite A105 Notebook
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
Dell G2210 22 inch LCD Monitor Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
