How do i set time on sharp image esi-b322-ca
Trying to set time and alarm clock lost manual
  • 3 Answers
SOURCE: Timex T158W Alarm Clock
Hold down the "buzzer", "radio" or "sound" buttons until you hear a beep and one of those words is blinking. then, use the arrow keys to go up and down by minute and only by minute (which means you are going to have to wait awhile if you want to change the time to many hours ahead or behind). When you get to the time you want, press enter.
Posted on Dec 15, 2007
SOURCE: Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Posted on Jan 25, 2008
SOURCE: How to set time/alarm GE Auto Clock Set Radio Model 7-4892A
I have a solution for the GE Auto set clock and radio model number 7-4892A. The only way that I had found out just by accident is that you are suppose to hold down the manual clock set until you start to see the Year and then the Date. There you will be able to set it to the correct date or year.
Idea from
Guest
Posted on Mar 11, 2008
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Posted on Jan 08, 2009
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
Posted on Mar 04, 2009
How do i set the time?
Have you tried Sharper Image ? on customerservice@sharperimageonline.com
Surely they MUST be able to help with an instruction manual if you ask nice.
Aug 10, 2014 | Sharper Image Relaxx Dual Bedside Audio...
How do i set an alarm on my centrios clock radio
Try these instructions to see if it works for you.Setting the Alarm
1. In the Normal Time Display, press "MODE" key to enter the Alarm Time Mode.
2. Hold "SET" key for 2 seconds until HOUR digit flashing.
3. Press "ADJUST" key to increase the setting value.
4. Press "SET" key again to step the setting items. The sequence
will be: Hour > Minute.
5. Press "MODE" key to exit the setting mode.
See page 3 on this manual.http://downloads.thesource.ca/631/6316008/manuals/manual.pdf
Jun 02, 2014 | Audio Players & Recorders
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
I need discovery kids tm daisy clock manual
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between month/day/year/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial near the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time)
Good Luck!
Jun 22, 2013 | Toys
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
Dec 03, 2012 | Discovery Channel Discovery Kids - Rocket...
I need to change time zone on atomic clock to EST
I need help setting the time zone on the sharp atomic clock model #spc364.
Apr 18, 2009 | Bose Wave Radio
Sharper Image Projection US Atomic Alarm Clock (model number OQ311)
try looking up the manual on the model number you might find it online. I have the maual for this model.
Jun 10, 2008 | Audio Players & Recorders
Military time
I have the same problem. The clock changed to military time after we experienced a power failure. I have tried to correct it by holding down the "Alarm Set" button and hitting the "On/Off" button at the same time. It works while the buttons are pressed but immediately reverts to milirtary time. Any other suggestions?
Mar 30, 2008 | Bose Wave Radio II
Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
Sep 20, 2007 | RCA Radio Alarm Clock
Sharper Image GT113 Beetle Clock radio
Sorry, no luck with a manual for the GT113, here is the link for the manual for it's replacement, the GT806; http://www.sharperimage.com/us/en/catalog/productdetails/sku__GT806 Check page 16 - hopefully the process is the same on your model for the alarm - other features are definitely different. Please ask again if this doesn't work. Hope this helps :)
Jul 15, 2007 | Sharper Image GT113 Clock Radio
248 people viewed this question
 Grubhead
Grubhead
