Question about HP ProBook 4530s Notebook
Pci slot 5 (pci bus 37, device 0, function 0)
4 Suggested Answers
kamacosmic
  • 135 Answers
SOURCE: PCI Slot 5 (PCI bus 7, device 0, function 0)
Firstly you wont get anything searching that cause it is not a model number or brand of a network controller. Look for a yellow question mark or a small red cross under all the devices. If this doesnt work get the program called 'everest' which will tell you the name of your network controller to run your LAN.
all the best
kc
Posted on Feb 23, 2011
TechyDrood
  • 2072 Answers
SOURCE: getting the following error on
If it is not making it to Windows at all...Generally occurs when two devices are using the same IRQ or memory allocation. This can sometimes be set in BIOS depending on the manufacturer etc. I would start by going in BIOS and restoring the default settings. There should be a menu item in BIOS usually something like "Restore Default".
If it is making it to windows then you probably just have a missing or corrupt driver. Generally this would fall under a chipset driver which can be downloaded for free from hp's site. You can also download and run Everest or SIW to properly id the device in question.
Comment back with for findings results or for more assistance.
Posted on Aug 26, 2011
SOURCE: PCI Slot 2 (PCI bus 35, device 0, function 1)
Download and install the chipset drivers
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Chipset drivers.
Posted on May 10, 2012
PCI Slot 4 (PCI bus 5, device 9, function 0) driver
The PCI slots are cover by the Chipset driver. Go to Asus.com and download the latest driver and install it.
May 29, 2011 | ASUS A8N-SLI Premium Motherboard
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
PCI Slot 1 (PCI bus 2, device 2, function 0)komputer saya tidak ada drivernya, bagaimana cara mendapatkan drivernya?saya menggunakan laptop merk IBM Thinkpad T42. Terima Kasih.
PCI Slot 1 (PCI bus 2, device 2, function 0)komputer saya jg tidak ada drivernya, bagaimana cara mendapatkan drivernya mas.
merk laptop saya Compaq Presario CQ43
Jul 31, 2010 | Computers & Internet
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
PCI Slot 1 (PCI bus 1, device 10, function 0)
Hi there,looks like your devices need updates to function correctly,
from devices manager,
select the device with the yellow question,
right click and click on update
even if you have no disk or internet
let the wizard find the drivers automatically
should be preinstalled with your OS XP
go thru your list and update any other question marks in yellow.
Should be able to update the network device on this system and then connect to the internet to finish anything else
heres the link for the Chaintech motherboards
http://www.download-device-drivers.com/Chaintech.php
Hope this helps,Cheers Misterdj
Jun 19, 2009 | Chaintech 9LIF7 i845G Motherboard
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Apr 10, 2009 | IBM ThinkPad T60 Notebook
PCI Device Conflict
u can try to change in BIOS, the settings that manages PCI IRQ's. If it is on manual then put it on auto mode. If on auto mode than manualy change the allocations of irq for the pci slot no. 5 ....
Jan 20, 2008 | EPoX EP-9NPA7I (0819366003415) Motherboard
HP ProBook 4530s Notebook Logo
188 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
