Question about RCA Lyra RD1072 MP3 Player
Menu key pad is stuck won't pop back up
Menu key pad is stuck down
  • 39 Answers
Remove the battery, take off the cover and, using a q-tip soaked in wd-40 seems to work best, clean the contacts...also if the button itself pops out soak it in warm water to get w/e gunk out that might be in there.
Posted on Jan 22, 2009
How I delete a bookmark from front page
  • Open Safari by clicking on the Safari icon in your Application Dock. If you do not have Safari in your dock, click the Finder icon in your dock to open the Finder window. Click on the Applicationsicon1.png icon in the far left column of you Finder window, and then double-click the Safari icon.
  • 2 Identify the bookmarks you would like to keep and the ones you would like to delete. Safari has a bookmarks bar and a bookmarks pull-down tab. Delete bookmarks that are saved on your bookmark bar by hovering the arrow over the bookmark you want to delete. Press and hold the "Control" key and click your mouse pad. A pull-down menu will appear; highlight the "delete" option and click your mouse pad. The tab will now be deleted from your bookmark bar.
  • 3 Delete bookmarks in the pull-down menu by clicking the Bookmark tab at the top of your screen. Select the first option called, "Show all bookmarks." Select the "Bookmarks Menu" option in the left hand column of the window that pops up. Hover the arrow over the bookmark you want to delete. Press and hold the "Control" key and click your mouse pad. A pull-down menu will appear; highlight the "delete" option and click your mouse pad. The tab will now be deleted from your bookmark bar.
  • Read more:
    Apr 21, 2014 | Apple safari
    Cursor has frozen what can i do
    Couple of things you can try
    Try 1 :
    1. Press the windows key on your laptop and see weather the start menu pops up 2. If it pops up then the problem is with your laptop touch pad 3. Try ALT+CTRL+DELETE 4. Use the TAB to get to the Turn Off button and click that then turn on again
    Try 2: 1. If the windows start menu did not pop up 2. Then your laptop is stuck 3. Press and hold the physical on/off button of your laptop then your laptop will turn off
    Aug 06, 2011 | Acer Computers & Internet
    The left lower button on the touch pad is stuck down up still works. seems like it is worn or waring out. can this be fixed by me? thanks
    Yes it can be i think the button spring is stuck down .
    1 try to put the finger on it gently and rotate it clockwise and anti clockwise slowly and gently if it dosent pop out you take a very thin pin or so and try to insert it from down and try to pop it out but be carefull dont apply a force or you can brek the loks once it comes out you press the rubber part down slowly slowly if it comes out it will be in the normal position.and then put back the key by fixing the lock as it was before
    and should be ok.
    if dose'nt get fix then have to take it for service center.
    thanks
    Dec 12, 2010 | Computers & Internet
    The function key is stuck on and the strat menu
    What you need to do is to get a skinny flat tip screw driver and pop it back into position. But be careful though because if you pop it off you might not be able to get it back on. I have popped my f8 key on my laptop and haven't got it back on due to some tiny plastic pieces that if you don't have on correctly you won't be able to pop it back on. If you bought the laptop recently you may be able to go where you bought it and see if they can fix it for you.
    May 29, 2010 | ASUS Eee PC 900 PC Notebook
    Left click key doesn't bounce back when clicked. Seems stuck
    The key is stuck you have to be very careful if you are going to attempt to repair this.Turn the computer off and remove the battery before you attempt to repair it.Try prying it up with a thin knife blade.If this pops up and is working make sure it works as good as the other side.If not you will have to replace the palmrest.
    Good Luck
    Mar 21, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
    My volume menu from monitor pops up, volume auto-decreases
    Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
    Hope this helps!
    -- RT
    Sep 02, 2009 | HP w2207 Monitor
    Certain letters pop up with numbers, menu acts as call log
    only chance of getting things back to normal is to replace your key pad board by a new one !!!!!!
    Jul 21, 2009 | Cell Phones
    N81 8gb,keypad lock switch not working
    check kep pad connector
    or - chnga ic
    Mar 26, 2009 | Nokia N81 Smartphone
    Keys sticking
    you have to remove individual keys they normally pop off by levering them easy not by hard force and you need to clean underneath them and pop them back on
    Jul 24, 2008 | Datadesk (TK-3310) Keyboard
    Key pad virus
    This is more likely a stuck key than a virus. Check all of the buttons and keys on the phone, and make sure they move and feel normal. Power down the phone, pop out the battery, and then try it out again. If the problem remains, try resetting the phone through the settings menu. Make sure you back up your phone first, as this will wipe out all of your phone's data.
    Dec 15, 2007 | Motorola Mobility RAZR V3
    RCA Lyra RD1072 MP3 Player Logo
    24 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
