Question about Nixon El Dorado NIX0010 Wrist Watch
Nixon Channel T replacement strap
I have a Nixon Channel T watch , men. I need a replacement wrist band for my watch but I don't want to send it to the US. Where can I get one?
Thanks!
  • tripplee Apr 07, 2009
    same problem, my top strap broke on Nixon Channel T (black band)b. If your bottom strap (without the metal piece broke, we could swap. tripplee@aol.com
  • Arturs Kalnins
    Arturs Kalnins May 11, 2010
    what country do you live? What are all the numbers on caseback?
escapement
  • 2334 Answers
SOURCE: tighten wristband of the Nixon Watch , remove links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 05, 2009
SOURCE: Nixon Watch band
I tried the hammer plyer thing way back but took a bunch of time and stress, then I took it into a skate shop where they sold nixon watches and they had an actual tool supplied by nixon and all the **** needed to do the job.
Posted on Nov 27, 2008
escapement
  • 2334 Answers
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Posted on Feb 10, 2009
escapement
  • 2334 Answers
SOURCE: Nixon Channel T replacement bando
This is not exactly the same model.
Posted on Mar 15, 2009
  • 183 Answers
SOURCE: Mens Versace leather strap. How do I adjust the
Well i am going to roll the dice and assume you have one of the ez clasps but if I am wrong you can send the model number and we will figure it out.
To adjust the ez clasp pull up on the front of the clasp loop while pushing down on the band. Rather than the traditional buckle and prong set up, the prong here is underneath the clasp loop.
Hope this helps. Thanks!
Posted on Sep 20, 2009
I need a replacement band for a fossil watch number 741010; I see a number on the band of 7413500. Could you help me find a replacement band?
On the back of the watch should also be a 6 digit code consisting of 2 letters and 4 numbers. For instance CH3000.
With that code you should be ablte find your strap here: http://www.mastersintime.com/en/straps/
Oct 17, 2017 | Fossil Watches
COULD YOU HELP ME PLEASE
You should take the watch to a local jeweler / watch repair shop in your area that deals with that brand. If not, contact Nixon by this link-
http://online.nixon.com/us/en/repair-center
Aug 23, 2016 | Nixon Watches Mens The Graduate SS Watch...
Hello I have two nixon men's wrist watches that
just bring your watch to Nixon watch experts. they have spare and tools to repair your watch.
Jul 14, 2011 | Watches
New band
If you do not have a local dealer for these watches then, having looked closely at the illustrations on their web site it looks to me as though a standard strap should fit.
Have you already tried a local supplier?
(The makers web site is no help, as there doesn''t appear to be an english version but I can understand most of the description and replacement straps are not offered.)
May 29, 2010 | Vanceur LG43W Wrist Watch
I need a new watch band for my Nixon Scout watch
Try contacting a Nixon service center.
You can locate your nearest service center by going to their web site "www.nixonnow.com/dealers/" and filling in your details.
Mar 02, 2010 | Watches
How to change the battery on a Nixon Scout Watch?
Feb 10, 2009 | Nixon Scout NIX0013 Wrist Watch
Jan 24, 2009 | Watches
Nixon watch warranty info?
I have the exact same watch and problem. The local Nixon dealer told me to take it to them and they'd send it away to be fixed. Good luck!
Feb 26, 2008 | Watches
Nixon El Dorado NIX0010 Wrist Watch Logo
2,535 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
