Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Daytek 42'' Plasma TV flickers bright and...
By Mergatroid on Jan 22, 2009
Ok, it's my turn to ask for help.
I have a Daytek 42'' plasma TV for service. There is no service manual available for it. It uses an LG panel.
The x-driver PCB was shorted. Lucky we had a used one here in stock. Iinstalled it, but now the TV flickers bright and dark. When it's darkit almost looks like a negitive image, but will flicker bright againand look good before flickering back to dark. I have replaced the powersupply board, and I am about to try a main board, however there areseveral pots on the Y-driver board (5 pots), and I have a feeling itmight be an adjustment. There is also a pot on the x-driver board, Imarked it and tried adjusting but it made no difference at all. I putit back to the factory position.
Any ideas would be appreciated.
Comments:
Jan 22, 2009
- Note, we have just tried another main board but it has made no difference.
Jan 26, 2009
- Note 2, we have tried another power supply pcb, still no luck.
Same Problem
Mar 07, 2009
-   my nu/tec 54cm tv it so dark and even when i increase the bright it makes no difference, it keep on flikering bright and dark-   Guest
Mar 07, 2009
-   my nu/tec 54cm tv it so dark and even when i increase the bright it makes no difference, it keep on flikering bright and dark.
-   Guest
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
how to unlock sansui channels
Answer
how to unlock channels
Answer
Jai une ancienne télé de votre marque et en... (More)
Answer
I purchased a brand new plasma model 42 pf9630A/37 in 04.In nov 09 the plasma stopped working.Turn... (More)
Answer
My screen has dark spots in the upper corners that seem to be growing. Could the bulb be... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Flat Panel Televisions:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
