Question about Berger Instruments Magna-Trak 102 Metal Locator for Ferrous Metals w/
How to remove sensor from magna trac 102 - Berger Instruments Magna-Trak 102 Metal Locator for Ferrous Metals w/
    Scholar:
  • 87 Answers
The only way to remove the sensor tube, is to pull on the ribbon cable until it comes out of the metal tube. It wrecks the sensor tube. Only do it, if you have a new sensor tube to put back in.
Posted on Nov 26, 2014
How to replace the fuel pressure sensor on a 2005 ford explorer sport trac?
Google a picture
If you do not know where to look for a fuel sensor
I would assume you don't know how to test it & don't
have the skills to be doing that type of work
No parts get replaced until they fail a test
Jul 23, 2014 | 2005 Ford Explorer Sport Trac
How do i remove dashboard from magna jt
Can you please give more info on your Magna?
Mar 20, 2014 | Vehicle Parts & Accessories
Removing the seat from a Honda V-45 Magna Motorcycle
Hi, Ron for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How do you remove the seat
How do remove the seat of my Honda Magna
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
Nov 29, 2013 | 2001 Honda VF 750 C Magna
1997 Honda VF 750 C Magna can't remove the radiator cap
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1994 2003 Honda Magna VF750C Coolant Change
Motorcycle Coolant Change How to
Nov 24, 2013 | 1997 Honda VF 750 C Magna
1983 Honda VF 1100 C low fuel light not working
Hi, John and the usual suspects are:
1. Blown instrument fuse.
2. Faulty sending unit.
3. Faulty wiring between sending unit and gauge.
4. Faulty ground or power connection.
5. Blown indicator light.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1984 Magna Low fuel sensor
Honda Magna low fuel sensor repair
Honda V65 MAGNA Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vf-owners-manuals
Mar 15, 2013 | 1983 Honda VF 1100 C
Right axel outer universal joint needs to be replaced? How do you replace it.
Removal & Installation
See Figure 1
  1. Raise and support the vehicle safely.
CAUTION Brake linings may contain asbestos. Asbestos is a known cancer-causing agent. When working on brakes, remember that the dust which accumulates on the brake parts and/or in the drum may contain asbestos. Always wear a protective face covering, such as a painter's mask, when working on the brakes. NEVER blow the dust from the brakes or drum! There are solvents made for the purpose of cleaning brake parts. Use them!
  1. Remove the wheels and brake assemblies.
Refer to Brakes for the proper procedures concerning brake removal.
  1. Remove the cotter pin, locknut and axle hub nut.
  2. Remove the hub-to-knuckle attaching bolts.
  3. Remove the hub and splash shield from the steering knuckle.
  4. Remove the left axle shaft from the housing.
  1. If equipped with Command-Trac, disconnect the vacuum harness from the shift motor and remove the shift motor from the housing.
Remove the right axle shaft from the housing.
remove c clips from u joint remove caps install new u joint install clips
To install:
  1. Insert the left and right axle shafts into the axle tube.
  2. To install the right axle shaft (with Command-Trac) first be sure that the shift collar is in position on the intermediate shaft and that the axle shaft is fully engaged in the intermediate shaft end.
  3. If equipped with Command-Trac, install the shift motor, making sure that the fork engages with the collar. Tighten the bolts to 8 ft. lbs. (11 Nm).
  4. On the left side, install the axle shaft in the housing.
  5. Partially fill the hub cavity of the knuckle with chassis lube and install the hub and splash shield.
  6. Tighten the hub bolts to 75 ft. lbs. (102 Nm).
  7. Install the hub washer and nut. Tighten the nut to 175 ft. lbs. (237 Nm). Install the locknut. Install a new cotter pin.
  8. Install the brake assemblies.
  9. Lower the vehicle.
Sep 13, 2010 | 1996 Jeep Grand Cherokee
2004 Sequoia. VSC TRAC, TRAC OFF, and Check
It is not hard to change the sensor, it just screws into a threaded hole. The light will not go out immeditaly, after the sensor is replaced. It needs to go thru a drive cycle. Your best bet is to replace the sensor and get the code cleard by whoever scanned it for the 0031 code.
Jul 23, 2009 | 2004 Toyota Sequoia
The trac off, trac on light is on, along with the low tire pressu
trac on trac off (traction control system)
tyre preasure light on mean that these sensors
may have been damaged or placed out of calibration during your brake repair
Jun 23, 2009 | 1999 Oldsmobile Alero
Berger Instruments Magna-Trak 102 Metal Locator for Ferrous Metals w/ Logo
76 people viewed this question
Top Berger Instruments Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Berger Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
