Question about Canon ZR40 Mini DV Digital Camcorder
My Canon ZR40 says "remove cassette" every time I rewind.
Sometimes it even eats the tape so that when I do try to remove it the tape comes out of the cassette.
  • fkulczak Apr 03, 2009
    Mine does it too.The eject cassette icon comes up and so does another blinking red icon(I can't find this anywhere in the manual) that looks like a small trapezoid: parallel top/bottom with angled in sides but with a slah line thru the middle.
    The last tape ejected was stretched and ruined in the ejecting.
  • Anonymous Apr 30, 2009
    I have the same problem. My device was stored for more than a year and when i used it, impossible to rewind my casset.
5 Suggested Answers
  • 883 Answers
SOURCE: Eating Tape when rewinding in vcr mode
look for a tiny pinhole and insert a pin while powered up to reset the device. if no-go, then the take-up reel needs attention...needs possibly a new or well-cleaned-with-alcohol-swab rubber belt
Posted on May 27, 2007
  • 64 Answers
SOURCE: Remove Cassette Error
I repair gl2s for canon and when you get a remove cassette message 9 times out of 10 it is 2 gears on the m-chassis that have failed they spit oil all over the inside and then the gear comes in contact with the m-chassis and binds up they are both white and in the middle you can see one when you open it and the other is on the inside that you cant see unless you take take the cover off and thats why you get that message but the ribbon part is something else that needs to be looked at you should send it in to a qualified canon repair facility. tell them the chassis is defective its actually code D106, E52, send those codes in with canon and make sure they see them.
Posted on Nov 16, 2007
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
SOURCE: Canon GL1 Remove cassette error
I certainly don't intend to be rude or obnotious but your comments on this known prpblem are contraditory to say the least! :
"The problem that you are experiencing with your Canon GL1 camcorder is a common complaint on this model camcorder. The “eject the tape error” is the camcorders way of saying something is wrong and it needs to be sent in for repair. It is not a defect with the camcorder, it is simply the most common complaint when the mechanical assembly is not running smoothly and perfectly." If something is wrong and it's a common problem then it must be defect?!?! Also your pricing for this "repair" is pretty close half of what a used GL goes for over here in Europe. I would definatly be looking for another quote and repair service other than yours!
Posted on Aug 20, 2008
Camcorder VHS tape is tangled
Sometimes you can salvage a VHS tape by opening the cassette and manually winding or rewinding the tape to put the damaged section to one side and under tension to "iron out" the wrinkles. Your Fuji Hi8 tape may be quite thin so this repair may not work.
Dec 18, 2013 | Canon ES300V ES4000 ES410V and ES420V ES50...
My canon vixia hv30 camcorder is not reading tapes anymore. It rewinds and forwards and reports the tape position but the tape counter does not roll showing only dashes as if the tape is empty. All this...
It sounds like the tape itself is damaged. Get an head cleaner cassett and clean the mechanism. This will clean the wheels and heads that tape runs over. Also try a new tape cassett to see what happens and listen to the camcorder for any crunching sounds as this would suggest that something has broken inside the camcorder.
Good luck.
Jun 29, 2010 | Cameras
Can you erase the tape on a canon zr40 digital video camera so i can start over
You don't have to erase the tape, just rewind and start recording over existing video.
Nov 19, 2009 | Canon Video Cameras
During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Apr 18, 2009 | Canon ZR40 Mini DV Digital Camcorder
Cassette player is eating tapes
Hey there.
Cassette head cleaners generally only improve the sound quality on playback. This problem sounds more like something mechanical; I would open the player and check out the capstan and rollers. If they are dirty, clean them with a mild soap and water solution, (carefull to not get it too wet). Also, as for the tape deck in your vehicle, OEM systems are notorious for eating and destroying cassette tapes.
Let me know how this goes over,
Mar 22, 2009 | Audio Players & Recorders
FUJIX-8 F60wide eats tapes when I rewind
You should e able to use any head cleaner, as long as it is the right size for you camera, but that is deffinitely your problem.
Feb 13, 2008 | Canon XL1S Mini DV Digital Camcorder
Cassettes not rewinding
The heads could also just need a good cleaning, either professionally or using a head cleaner dv tape. It's important to remember to always use the same manufacturer dv tape all the time. Evidently, Sony and Panasonic do not mix well, and the lubricants from those two tapes combined will gum up the works. If you use Sony dv's, always use a Sony head cleaner and vice versa. Cold can also cause those lubricants to gum up. Sometimes simply fast forwarding will loosen things up.
Nov 25, 2007 | Video Cameras
The problem that you are experiencing with your Canon GL2 camcorder is a common problem on your camcorder. Check out this video for more information.
Sheryl Bahr
Nov 13, 2007 | Canon GL2 Mini DV Digital Camcorder
Eats tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Apr 04, 2006 | JVC HR-J461MS VHS VCR
Canon ZR40 Mini DV Digital Camcorder Logo
360 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
