Question about Hoover F5835900 Upright Steam Vacuum
Not suctioning the water back in
I cleaned and noticed that all the clean water was gone, but no water in the dirty water bucket
reddevil6
  • 1673 Answers
SOURCE: Suction button
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter
Posted on Jan 10, 2008
  • 126 Answers
SOURCE: not sucking up dirty water
The F5914 has a lid that must be engaged with the tank in order for the suction to reach the floor. Gently lift the front of the lid on the tank and if it lifts up, you haven't engaged the two tabs on the tank into the lid. Remove the lid and make sure the tabs on the tank fit into the grooves on the lid and snap it closed. This should solve your problem. Also, make sure that the removable duct in the front of the tank is in place. It is removed when the hose is used, but must be replaced when the machine is used on the carpet.
Posted on Feb 02, 2008
micromaster
  • 3614 Answers
SOURCE: Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Posted on Jun 01, 2008
galati2k
  • 281 Answers
SOURCE: Wont suction the water
the suction channel is probably clogged.the suction channel goes right up the middle ,you can see it by looking through the cover.probably a lot of hair and dirt stuck up inside.there are some screws on the botton you need to take out then the cover will come off.seperate the 2 pieces of plastic and you will be able to clean the channel.please leave feedback
Posted on May 01, 2009
SOURCE: Hoover Agility Steam Vac has no suction for the dirty water
it is a broken suction hose i had the same issue cleaned the whole thing then i opened it up and leaned it all the way back when it sits up right it sucks it up but when you pull it back to do your dirty work the hose seperates cause its broke
Posted on Dec 21, 2009
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
My Hoover steam vac spin scrub will not suction up the cleaning solution . Why is there no suction?
p{margin-top:0px; margin-bottom:0px;} Hello,
Thank you for your recent e-mail. I am sorry to read about the problem that you are having with your cleaner.
Please make sure your recovery tank and lid are installed correctly and forming proper seals. Make sure that your filter is clean of any debris. Clean the screen in the tank lid. Make sure your nozzle and squeegee (if on your model) are free of dirt/lint/hair and attached in their holsters correctly. Make sure you do not have any clogs in the hose.
To restore suction, please try the following:
*Remove dirty water tank and clean filters- main reason for low suction is dirty filter
*Verify the dirty water tank cap is not missing.
*Verify dirty water tank lid is inserted completely into unit.
*When cleaning, the yellow float inside of dirty water tank should be free moving.
• First remove your clean water tank and unplug the machine
• Remove the dirty water tank lid and push the front panel piece (square plastic sliding piece in the front of tank) down to make sure it is inserted all the way.
• When reattaching the lid, hook the tabs on the front of the lid to the tank first, then click shut in the back. Pull up on the lid firmly, it should not lift at all. If it does, try reattaching as a seal needs to be formed for suction.
• Test to see if suction has been regained.
If these suggestions do not solve your issue please call a service center.
Your cleaner has at least a 6 month warranty for manufacturing defects. This warranty begins from the date of purchase, with the original sales receipt. If you do not have the original sales receipt, the warranty may be verified at the warranty repair center by MFG or serial number.
Please visit www.Hoover.com and click on service center locator for a list of authorized dealers in your area for service and warranty assistance.
Sincerely,
Hoover Customer Service 62
1-800-944-9200
Mon - Fri 8am to 7pm EST
**Please do not reply to this email address. This is for outgoing messages only.**
servlet.imageserver?oid=00da0000000yf5q&esid=018g0000005bxv6
ref:_00DA0Yf5Q._500G0AodT5:ref
Aug 08, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Leaving bigger dirtier wet spots after cleaning
Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Extreme vaccum has no suction.
Make sure you put the dirt cone back in the bucket to create the tight seal. You will have no suction without the dirt cone.
Bob
http://evacuumstore.com/
Dec 10, 2009 | Electrolux Centralux Vacuum
The suction is not working. we have tried all the
check RECOVERY TANK LID and DUCT
May be the duct is off the hook
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac spin scrub won't suction the water up.
I fixed my problem by repositioning the tunnel that is on the front of the pick-up tank. It had moved out of position and not allowing a tight seal. It is the white plastic piece that slides a little bit. Good luck.
Sep 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell 2x steam cleaner
Usually when it won't pick up water is because the bucket isn't seating all of the way down. Or there is a window gasket or seal, it goes bertween the clear window and the bucket, if it is missing, yiu get no suction thru that clear window. The other is on the one side of the lid for the bucket is a filter, is it clean? And the seal that that filter sits on, is it sealing? If the moror is running, it is sucking, but any leak will cause it to loose that suction.
Aug 30, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
No suction
Hmmm...I have the same problem...if you remove the water tank and the water collection bucket and look at what is remaining. Now step on the lever to lean the upright part back and there is a hose there that goes from the hand held hose into this hose into the dirty water tank. MINE is broken at that center point between the handheld hose and the dirty water square thingy...It's probably fixable...maybe this helps you?
Nov 05, 2006 | Hoover F7431-900 SteamVac Vacuum
Hoover F5835900 Upright Steam Vacuum Logo
22 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
