Question about Hansgrohe Plumbing
Spray doesn't work - Hansgrohe Plumbing
    Scholar:
  • 72 Answers
Could be water deposits blocking the performance of the hand sprayer. Try cleaning it with CLR to remove deposits. If you need help finding parts or dealers feel free to contact Hansgrohe at 1-800-334-0455.
Posted on Jan 14, 2013
How to unstick the ? key on my electronic ditionary?
Try wiping around the base of it with a damp Q-tip or baby wipe. If that doesn't help, get some spray electronic cleaner that is safe for plastics and spray a small quantity into the space around the key while tapping the key.
If that doesn't work, dissemble the keyboard and clean it that way. If that is not possible, look for a local shop that will work on it.
Aug 25, 2012 | Office Equipment & Supplies
My key will not turn my switch in my 2003 chevy impala
Try spraying dray graphite lock lube into the cylinder and work the key around. You can buy the lock lube dry spray from any hardware store. If that doesn't work let me know.
Jun 25, 2012 | 2003 Chevrolet Impala
My graco xr5 sprays when i turn tip to spray position
If paint comes out of the spray gun after you release the handle, your problem is inside the gun. If the needle tip or seat are damaged or the spring that holds them closed is broken, paint will be able to get past the the needle and will come out of the gun even when the handle isn't held open. The stock spray gun that comes with the the XR5 doesn't have any servicable parts inside it so if it isn't working properly it may be garbage fodder. If you have an aftermarket gun, rebuild kits may be available.
Jun 13, 2012 | GRACO INC Magnum Xr5
Upper spray arm on my Kitchen Aid dishwasher (8573025) doesn't work.
Arm operates(turns) by water pressure. If it does not turn no water is going to the top spray arm. make sure the setting washer is on does not preclude the top spray arm from operating(read manual). If not check arm by spinning by hand to make sure it is free. If arm is free and it still does not turn when DW is running than there is a restriction in the tubing to the upper spray arm or the check ball or solenoid are not operating correctly.
Mar 01, 2012 | Dishwashers
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a singer 603e that I just purchased from an estate sale. I got home and tried to use it, but the take up lever is stuck. How do I fix this?
try some wd 40, spray it on the area of the take up lever & let it set for at least 10 minutes then with the hand wheel on the right hand side slowly move the hand wheel toward you & if it still doesn't move re spray again & wait again then try the hand wheel again to move toward you eventually it should start to break loose if it's just stuck.
since you pruchased it at a estate sale, there not much telling when the machine was serviced last
if the spraying doesn't work, consider having it serviced
Aug 21, 2011 | Singer 3116 Simple
I can't get my float on my dehumidifier to work. It is in full mode although empty. The light keeps flashing.It doesn't seem to be making contact with the "switch" in the unit. Can you...
Just, gingerly jiggle the float ball rod and it should release and return to the down position.If that doesn't work the first time, spray a light coating of WD40 on it.
Jun 17, 2011 | Maytag M7DH45B2A Dehumidifier
Hello my probel is ny ps2 console slim editon,, its spinning slowly and not read,., plzz help
Thanks for choosing FixYa and welcome. You need to get a can of air spray and spray the inside. It is easy to get dust on the eye and in between the parts that turn the disc. If this doesn't work, you will need to take it apart and determine a cause then. You could have a loose wire, damaged part, or bad eye lens. When you spray it, spray at a distance. You don't want to get moisture inside the console.
May 09, 2011 | Sony PlayStation 2 Slimline Console
Plumbing Logo
53 people viewed this question
Top Hansgrohe Plumbing Experts
Andrew Bugbee
Ian Lulham
Ian Lulham
Level 1 Expert
ray gallant
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
