Question about Whirlpool Duet GHW9150P Front Load Washer
Error code E71
Don`t turn on
Main enigine Fan doesnt work
the problem is when you don't turn on the ac on and don't turn on the engine withou turning on the ac because than you won't be able to have any air and call the company of the car to fix the fan for you
Oct 12, 2012 | 2008 Dodge Caliber
Turn signals work but they don't return, how do I fix?
there's a little plastic piece inside the turn switch called a cancelling cam that broke or quit working. The only fix to get switch to return is replacing the turn signal switch. I don't think you can buy the part separately.
Dec 06, 2011 | Cars & Trucks
My turn signals don't work but the hazzards flash
if your hazzards flash, that means your bulbs will be good but, your turn signal fuse is blown. you should check that first, & don't forget to turn off your hazzards before you can see if your turn signals work again. give it a try.
Dec 01, 2011 | 2000 Dodge Caravan
Error 5200 or PO8?
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 12, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hi, if a 1982 Volvo don't start and don't even
It might not start because of a dead battery, starter. Altenators charge the battery. I wouldn't consider buying it, If I counldn't hear it run.
Jul 03, 2011 | 1982 Volvo 240 Series
The bike has power, but the turn signals don't turn on, it doesn't even acknowlegde that im pushing the indicator switches.
Contact me directly at wd4ity@bellsouth.net and I'll send you a trouble shooting guide for the turn signals. Don't forget to remind me of what you need.
Steve
Jun 28, 2011 | Harley Davidson XL 1200 C Sportster Custom...
No turn signals they come on but don't flash
It's probably the turn signal flasher. It is usually located under the dash along with the hazard light flasher. If you don't know what it looks like, then go to a parts store and look at a new one. Once you have located one, then remove it. Try the hazard flashers. If they work, then replace that flasher with a new one. If they don't, then reinstall that flasher and look for another one like it. When you find one, replace it with the new flasher and try the turn signals. (remember : the key must be on for the turn signals to operate). I hope this information helps you and thank you for using Fixya.com.
Jun 28, 2011 | Chevrolet TrailBlazer Cars & Trucks
Canon error p08 Problem
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 10, 2011 | Computers & Internet
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
