Question about Ovens
What is the price of magnatone fitted in microwave oven ?
Siemens HB86E560B/01 microwave oven.oven working ok.when selecting wattage for microwave it cutts out after approx.30 secs. higher the wattage selection the sooner it cutts off. is there an overload heat...
Please have your power rating checked on the outlet and also if possible measure the mains voltage on the outlet . If low this can trip the microwave as it runs short of current/voltage.
Also make sure the plug is tight on the socket. Choose a lower wattage and see if the microwave works a longer time. If so the microwave must be checked within for a faulty capacitor, magnetron , wave guide or transformer.
Clean the oven , check the connections within and try once again before we can infer.
Aug 19, 2011 | Ovens
1. my microwave oven is switching on. 2. Time is also displaying. 3. The porblem when start the plate is not rotating. I am getting sound as usual.
The most likely problem is going to be the plastic drive hub on the floor of the microwave that the plate fits into in the center of the plate.It's broke and cant turn the plate.to check it remove the plate and use a screwdriver and pop that hub out by putting the screwdriver under the hub and pop it up,in the part of it thats hidden till it comes out will probably be cracked. If that hub is ok the motor it fits into is the next potential problem.
Gene
Aug 08, 2011 | Ovens
How do you change a light bulb in a panasonic microwave oven
Usually you need to remove the outer case from the microwave to change the light.
If you are confident with basic tools, a DIY person, if not get an electrical person to fix it.
Make sure it is unplugged and leave off for 30 minutes or so. Unscrew screws at the back to loosen the outer case. Slide the case off Change light and re-assemble. Make sure the case is properly fitting it usually has lugs that fit into the front piece.
Jan 13, 2011 | Ovens
Hi I brought a Baumatic Microwave model GEM252TK and I need the spec to fit it in to my new kitchen and I cant find it cheers
You can download a brochure - with the dimensions of the microwave - free from here:
http://www.baumatic.com.au/smart/media/Baumatic_2010.pdf
The dimensions are at the bottom of page 25. You can view, print and or save this file. If you need the general specs e.g. power rating/features, you can find them here:
http://www.baumatic.com.au/smart/25l-microwave-oven-with-grill.html
Please rate this solution if you find it helpful. Thanks.
Oct 23, 2010 | Ovens
Microwave oven not heating
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Oct 06, 2009 | KitchenAid Architect® KEMS308SSS Stainless...
I have a whirlpool oven model no. G2P61/01SR/WH. It does not heat
The problem lies in your magnatone used for heating up the oven.You need a replacement for that.
Jun 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
Microwave door shattered
This is not a job you should do. Microwaves are dangerous things and can cause injury. An improperly fitted door will leak. A new door, installed and checked out by a technician is needed here The economics are beyond my area.
Jun 16, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
