Question about MSI K7N2 Delta-ILSR Motherboard
Mother board died...
I think my mother board died so i was wondering if i could get one that i can just switch out my memory sicks, video card, etc. i havent been able to find the exact one i have online or any stores. what can i get that is campatible with a Msi K7n2 delta-ILSR?
    Sergeant:
  • 367 Answers
Have you tried ebay ?
Posted on Jan 22, 2009
Comp does not turn on. green light off but goes on when mobo disconnected
Test the power supply in another computer.
If that works, the next thing is to check the mother board. Remove all daughter boards from the slots. Remove all memory, disconnect all hard drives, cdroms, etc.
Make sure there is nothing plugged into the mother board except the video cable (if it is on-board video), if not, then make sure you have a good video card plugged in.
Again with no memory, no boards except a video card, if needed, and the power plugged into the board.
Turn on the power, and watch the screen. If it works, then you should get a notice that there is no memory, no hard drive, and so on.
If that is the case, then proceed to install one item at a time to isolate the problem. If it is not the case, the the mother board is probably bad. One other thing to check would be the CPU.
If you get no notice with the above, then the cpu could be bad. Check it in another computer, if possible. This should tell you what the problems are or is.
In the above cases, either the cpu or the mother board can be isolated to see what is bad, if any.
Oct 07, 2009 | HP Computers & Internet
Ac 97 audio
i suggest cleaning the components first specially the memory modules.. then the video card and other expansion cards.
Sep 05, 2009 | Computers & Internet
My motherboard are defective beforing booting no display usually block out what do you think...
hello there,
are you sure it was mother board,have you tried to swicth on your computer without hardisk,floopy and cd-room,if not try on
disconnnect i.d.e cable of hardisk,floopy and cd room,from your
mother board be sure to switch off or unplug your computer before doing this,disconnect also vga cable from your video card,pull out video card and memory card,scrub by eraser head of pencil the sloted terminal both side of your video card and memory card,then put it back,if you have multiple memory card have it clean all,put back memory card one card only,just to know if your windows appear on start menu,put back vga cable,swtich it on again,if windows appear put back all devices,but if not isolate memory card,and try other video card if have one,if strill black out,well that the time,it was a mother board problem.rate my skill if your satisfied,thanks a lot
Apr 29, 2009 | Intel Pentum 4 3.2Ghz System (SYP32) PC...
HP a1712n How to troubleshoot MOB problem?
you can consider 4 factor on no video,it maybe video card or memory card,processor last mother board this if PSU was good,you also check memory card to other computer,somerime need only to clean terminal slot of memory by pencil eraser,eraser slot then put it back,also video card same process in cleaning try also to other computer.Instale good memory card and good video card even with out hard drive,cd room the mother board.if does not run,defective motherboard,
Mar 16, 2009 | HP Pavilion a705w PC Desktop
Dell inspiron 1300 Video card upgrade
Sorry you cannot upgrade the graphics on your laptop according to the articles i looked up.
You should call DELL. I think the display card is part of the mother board on your computer. In this case, you cannot change it. In some models you can add some memory to the display card, but this may not make the card faster. Higher amounts of memory allows for more resolution and colours.
Dec 22, 2008 | Dell Inspiron 1300 Notebook
Need to disable internal video that isn't working
With internal video cards they normally automatically switch to PCI video cards that you put in without the need for switches or settings on the board. Just plug in the card and plug in the monitor on the card and you should be good. now if your board is one of the select few that require a change in the BIOS then you are out of luck. BUT, take note that 90% of the time that internal video cards do not work because of the memory. Take note that the memory that the internal video cards use is the memory on the board so you might want to check if your memory is working.
Aug 26, 2008 | FIC Computers & Internet
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
Power up
pull everthing off board but power supply ram cpu and heatsink. then try to power unit.
May 08, 2008 | E-Machines eMachines Desktop PC
Mother board
Firstly your motherboard doesn't have video capabilities built in so you have an addon video card. I doubt there's any problem with the board as it's jumperless and you can't have the CPU settings wrong. Are you getting any beeps when you switch on? The length and number of beeps can tell you where the problem is. The usual problem with no video is either a memory problem or video card problem. If you can borrow another video card try it. Make sure the plug is correctly inserted all the way in and make sure the video card is properly seated in it's slot. I assume you're using the 4x AGP slot. Remove that and try another ot even a PCI card in the PCI slots. You may then get a picture. Actually apart from finding it hard to figure out your actual problem it's very hard to diagnose a fault from the little you've told me. Certainly the motherboard can be faulty and you won't get video but it's the video card you should be looking at first. Have you turned the monitor on and plugged it in?
Jun 03, 2006 | Acer AOpen AX 6B Plus (91.87810.321)...
Open Questions:
See all MSI K7N2 Delta-ILSR Motherboard Questions
MSI K7N2 Delta-ILSR Motherboard Logo
65 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
