Also every ti,e I turn my Xbox on it goes straight to the update fail screen and won't come off no matter what button I press.. Help
SOURCE: XBOX 360 ASSESINS CREED UNREADABLE DISK
I do believe its a problem with the disk. The disk may not be scratched or anything but it could possibly something internally wrong with it. I'd take the disk back and exchange it. Hope this helped! Have a great day!
SOURCE: Xbox 360 disk tray wont stay shut
Do Not Call The Hot Line, 100.00 Dollars to just look at the problem thats not even fixing it. Waste of my time and money for there f--- up man.
SOURCE: I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
SOURCE: My Xbox 360 Won't read, not one disk.
Lens cleaners don't work very well . they tend to smear the
dust and dirt around in side the drive.
I have yet to find a dirty laser in an xbox 360 . This is
due to the high rpm of the drive sweeps most dust
away from the lens
It is more likely the laser is weak or dead .
The cost for a replacement is around 80.00 . 35.00 if you do
it yourself . feel free to email me if you have any questions.
Rob
Testimonial: "*thumbs up*"
SOURCE: purple screen - that reads update failed
I finally found out how to fix this! go to this website :http://thepiratebay.org/torrent/4801064/XBOX_360_Update_Files and download the torrent. Follow the directions from the second page of this forum: http://360mods.net/index.php?name=Forums&file=viewtopic&t=9796 . all you have to do is copy the $systemupdate folder that you need onto a usb drive and plug it into the 360 then turn on your 360. you can find out what number update you need by the number at the botom of the screen or if your like me and dont have those numbers youll have to go back and forth untill it boots up to the right update. make sure your flash drive is cleared out except the $systemupdate folder. go one at a time until it boots up with that update file.
