Washer wont agate
Model#fex831fs2
  • Washing Mach... Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Posted on Jan 12, 2013
3 Suggested Answers
  • 4 Answers
SOURCE: Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Posted on Mar 10, 2009
  • 142 Answers
SOURCE: washer fills with water, but then wont run
Check belt underneath has not broke or come off.
Posted on May 06, 2010
Washer fills with water, but then wont run
May 06, 2010 | GE Washing Machines
Maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Jun 01, 2009 | Maytag Legacy Series Top Load Washer
Mar 10, 2009 | Washing Machines
Wont fill and agatate
sounds like the water valve check for supply taps make sure there on test solenoid's on valve for ohms Resistance or closed circuitif open replace water valve
Aug 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
When spining it makes a gravel noise like there is dirt under the agatator and when the cycle has finished all bits of hard dirt have come out into the wash.How do l remove the agatator to clean under it?...
What type washer do you have? make? model?
Some agitator pull off, some are screwed down, some are bolted down, the bolts would be under the cap or fabric dispenser.
Jul 09, 2008 | Washing Machines
MAYTAG TOP LOAD WASHER MODEL PAVT244AWW, STRING FROM A CURTAIN IS CAUGHT IN THE AGITATOR. HOW DO I REMOVE AGGITATOR TO GET STRING OUT?
remove the fabric despenser from the top of the agatator, under the despenser is a 1/2 inch bolt, a ratche with a 6 inch extention works well, remove the bolt and the agatator will lift up off the transmission shaft
Apr 12, 2008 | Washing Machines
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
