Question about Canon Service Manual For Ir 6000
IR 6000 - Error conde E10,E12 and E14 after 5 to 10 min of starting
    Scholar:
    New Friend:
  • 134 Answers
Error E10/E12/E14: Main cause: The main motor (M1)(M2)(M19) is faulty. The DC controller PCB is faulty.Mode of detection:0000 The clock pulse do not arrive for 2 secs or more after the main motor drive signal
For more help you can check the canon iR6000 service manual from below link:
http://goo.gl/yhuA4J
thanks
Posted on Nov 25, 2014
I have johnson jet 7000 treadmill and its showing error 2 what can i do
HI,
Error 2 means P0 P1 P2 P4 P5 ( P0 ....Min. ,Speed P1 ....Max, Speed P2 ....Mid.Speed, P4 ....Min.Slope, P5 ....Max.Slope )have a wrong parameter values. You have to go the engineering mode and set the parameter. Here i have added a link which will guide you to the service manual of Jet 7000. read the section 4 (console maintenance mode guide) and re-calibrate the treadmill parameters P0 P1 P2 P4 P5 .page no(4.3).
http://www.cross-ir.com/Downloads/JET7000-6000-1.PDF
WWW.electro-medical.blogspot.com
Sep 16, 2015 | Exercise & Fitness
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
Error e 12 frigadaire front end loader washer
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
Dec 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Jun 27, 2012 | Canon Service Manual For Ir 6000
Bosch vision 300 gas dryer shows error E12 evry few min. Checked and cleaned lint. Checked exhaust vent. Still E12 every 10-15 min. The dryer is only 6 months old.
A friend of ours has a bosch gas dryer and she had the similar problem. She called the Bosch repairman and he came out to her house and sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Jan 17, 2011 | Bosch Dryers
Error code E10 on the electrolux ecovalve EWF1087 front load washer. What does this mean?
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Jul 22, 2008 | Electrolux Washing Machines
Casio tk 1300 error showing E03 - can't fix it with advice from manual
For those about a manual with error code solutions, C-tech has the one that covers these codes: E01, E02, E03, E04, E06, E07, E08, E09, E10, E11, E12, E13, E14, E17, E18, E19, E25, E26. It has remedies for each of the codes. You can find it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_operation_manual.html
Jun 30, 2008 | Office Equipment & Supplies
ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Jan 26, 2008 | Kyocera RI-3530 Black and White Copier
Canon Service Manual For Ir 6000 Logo
549 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
Tony
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
