Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-55513 ( HDTV 1080 ) Still flashing after DM board repair
Thank you for your great guide to repairing the DM board. My aunts Mitsubishi WD-55513 ( HDTV 1080 ) was doing the flashing light ( green led / timer ) non stop, and after reviewing your post I was certain this would correct the problem. I did exactly what you said, even got the replacement Radial Caps from Digikey, as the ones on her DM were indeed bad. ( bulged tops, and uF'ed questionable ) Anyhow, put it all back nice and neat, and the same problem as before. Any tips or ideas as to where we might look next? I feel with your vast knowledge of these systems it must be an oversight on my part. I would greatly appreciate any help or where I might try next. Thank you in advance!
  • Anonymous Apr 14, 2009
    I have the Mitsubshi 1080 big screen and replaced the 5 capicitors on the DM pcb for the continual blinking problem. However, this did not correct the problem I am still faced with. Any other suggestion would be greatly appreciated. Thanks. Wil..
    Scholar:
  • 47 Answers
There is probably a voltage missing on the secondary of the switch mode power supply . check for pico fuses.(the kind that solder in). Usually one other will open up and the same results will will appear because the set has protected itself from any more damage by a fusible resistor or pico fuse. I am impressed by your throughness in sticking with the solution of this problem. Make sure the set in unplugged and test all secondary pico fuses and current limiting resistors. This 1sv where you will probably find your problem. Everything you have done so far is mint. Scrivitron.
Posted on Jul 06, 2007
6ya staff
SOURCE:
I have a mitsubishi 64" medallion HDTV 1080. I have barely used it and the light in front is flashing wont turn on. it did this once before and the mother boad had gone out. Is there a way to get a new...
The blinking led is usually related to failed capacitors on the DM board. You can get the DM repair kit for your model at www.tvrepairworld.com its 35.00 and includes the replacement capacitors and the CD with instructions
Oct 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi HDTV
Press and hold menu button for 8 sec, then unplug for 1 minute. Plug back in and 1 minute later it will pop up for you.
Jan 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi wd-62725. my tv wont turn on and the timer light wont stop blinking.
Sounds like the classic bad capacitor problem on the DM pwb. You can get the V26 DM pwb repair kit at the following link which will usually repair the issue. Kit contains replacement capacitors and CD with chassis dissasembly and explains which capacitors need replacement.
Nov 28, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-55513 blinking power light
The infamous flashing green LED problem is usually due to a failing or faulty DM board. I purchased the PDF manual online and was able to locate and remove the components as necessary.
If you can solder, and are semi-proficient with electronics it is 4 bad capacitors on the DM board...
Otherwise there are facilities that can repair your failed board for about 275.00 or replacement of the board is between 350.00 and 500.00 buck USD.
Good Luck with your repairs....
-Richard (MetalDad)
email: [email protected]
May 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Need replacement DM Board ASAP
Go to this site and leave an email with the model number of your set and which board youre looking for they will be able to help you out, and they respond quickly
May 03, 2008 | Mitsubishi WS-55513 55" Rear Projection...
My 2001Mitsubishi 1080 hd Won't come on
Most Mits. models like yours will need a DM module repair or
replacement----either way, about 600.00.....T.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
168 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
