Question about Bose & Wave& Music System
Can I connect an equalizer to my Bose Wave System?
harishu
  • 18 Answers
SOURCE: bose series II active equalizer
it can be connected 2 ways. go through the manual from the link below
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Posted on May 22, 2008
marsrover
  • 682 Answers
SOURCE: Bose 901
1-record out from receiver to to equalizer in.
2-equalizer out to tape pb in receiver.
Posted on Nov 11, 2008
dunnbiker
  • 8546 Answers
SOURCE: Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Posted on Apr 13, 2009
dunnbiker
  • 8546 Answers
SOURCE: Bose 901 Equalizer connections to Harman Kardon AVR520
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
If your receiver has Pre Audio OUTS so I'm betting your receiver does, too.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Posted on May 16, 2009
Ganx
  • 113 Answers
SOURCE: adding turntable to bose music wave system
Hiya, sad to say it wont work even with the correct plugs. If you really need/want to get it going, you will need a RIIA pre amp to use to convert the turntable levels to an acceptable level for the bose. Once you have that, then get the correct matching plugs for the bose (sames guys that supply the preamp should be able to help). Suggest a google search in your area "RIIA PREAMP" and see who supplys.
Best of luck
Posted on Jul 16, 2009
Can I connect my Bose wave music system to my LG LED TV LB55, lb56,lb62
Of course.
At the rear of your TV, find the Red and White RCA sockets, which are the Audio OUT.
At the rear of your Bose, find the Red and White RCA sockets, which are the AUX IN.
Using an RCA audio cable, connect those 2 pairs of RCA sockets.
Then, on your Bose, select AUX as the source, and if you've done EVERYTHING correctly, your Bose will now be the speaker system for your TV.
Feb 22, 2015 | Bose & Wave& Music System
Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
Sep 02, 2012 | Bose Wave music system Multi-CD Changer...
Want to connect Bose acoustimass3 series iii to my Bose wave 3
Download the user manual to your Bose device from net. It will have all connection details.
May 23, 2012 | Bose Acoustic Wave® Shelf System
I have a Bose Wave Music System and I"m trying to
How are you connecting the sytem to your PC? are using an RCA cable (red and white connectors) from you computer to the system?
Mar 20, 2011 | Bose Acoustimass 6 III System
Would like to connect Bose Acoustic Wave II sustem
If your TV have audio output ( RCA or any kind ) then you can hook that up ( you can buy the cable from radio shack ) then to BOSE audio input w/c is the AUX input.
Apr 26, 2010 | Bose Wave Radio
How to connect my Bose Wave System to two outdoors Bose speakers?
It won't connect to externa l speakers directly but you could take the RCA output to an amplifier that drives them.
Aug 29, 2009 | Bose & Wave& Music System
Trying to connect external speakers
check with radio shack to see if they have something that will plug into the rear jack of the Bose...and has leads that you can wire to your speakers
May 27, 2009 | Bose Wave Music System CD Shelf System
901's directed to TV
Yes, you can plug your TV directly into the Bose 901 Equalizer, but you will still need to go from the EQ into an amp to drive the speakers. The Bose EQ basically is for the speakers, not the signal coming in to it. Because of the speaker design, the EQ "shapes" the sound to compensate for the speakers. Please rate my answer, thanks.
May 22, 2009 | Bose 901 VI Main / Stereo Speaker
Bose & Wave& Music System Logo
42 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
