Question about HP DeskJet 932c InkJet Printer
Hp932c all lights blinking, cartrdgs won't move when open, no pri
I have a hp 932c. All lights are blinking, and when i open the lid - the print cartridges don't move along the track. Can't print. I've tried to unplug all cords several times - but same thing keeps happening.
  • tenettsto Jan 22, 2009
    Hmm - thanks for your response - but that didn't seem to work. I've tried moving the silver clip toward the back and manually moved the carriage. Nothing. Un-then re-installed ink - nothing. ugh!
  • nifcoxy Feb 02, 2009
    The same thing is happening to me right now. Last night, my husband called me into the room because the paper was stuck, I pushed the "paper" button and the paper fed itself out, and now the green light above the power button and the orange light above the paper button are blinking in unison. Nothing seems to make it stop. The ink cartridges won't move back to the middle when I open the top, and they are making a horrible grinding noise in there. Sounds like the thing is going to self implode.
    Scholar:
  • 97 Answers
Please click on following link and follow the document, which will help u to resolve the issue,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&lc=en&dlc=en&cc=us&product=60096&rule=21430〈=en
Regards,  raj_p5983
Posted on Jan 22, 2009
How to find ink levels in hp932c printer
Print Cartridge Status The Print Cartridge Status Light flashes when one or both of your print cartridges are low on ink, improperly installed, or malfunctioning. It will also flash if you are trying to use the wrong print cartridge type. If the problem is low ink, the light will stop flashing when you open the top cover. For any other print cartridge-related problem, the Print Cartridge Status Light will continue to flash. To check the status of your print cartridges, open the printer's top cover. The yellow arrow on the print cartridge cradle aligns with one of five Print Cartridge Status icons.
Jan 08, 2011 | HP DeskJet 932c InkJet Printer
The printer is printing jibberish and canceling all documents doesn't seem to work HP932c
Power off everything for more than a minute, and try again. You may have to uninstall the printer, go to HP.com, and download install program and follow those directions exactly, often NOT plug and play.
Sep 28, 2010 | HP DeskJet 932c InkJet Printer
Hello, My HP 932C has suddenly started printing photos in pink. I have tried cleaning all the cartrdge contacts, reinstalling the software, a new cartridge. No change. Any ideas?
Your cartridge may need to be replaced. If your tri-colour cartridge has run out of yellow and cyan and only has red left this could be the cause.
Jun 08, 2010 | HP DeskJet 932c InkJet Printer
I thought I was out of black ink, so I replaced the #45 black ink cartridge in my DeskJet 932C printer and it still won't print in black ink.
check the printhead especially the black partition and see if the nostril on the printhead are not damage. does the ink lid blinking if yes clean or replaced the cartridge
Aug 30, 2009 | HP DeskJet 932c InkJet Printer
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
Failure to print
Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
J
Aug 29, 2008 | HP DeskJet 932c InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Jul 19, 2008 | HP DeskJet 932c InkJet Printer
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
120 people viewed this question
Ben Johnson
