Question about HP OfficeJet D135 All-In-One InkJet Printer
Jets clogged? I just received this all-in-one form someone who had it in storage. It was stored w/ printing cartiridges installed, but they were expired. I have gotten new cartridges, but it doesn't print correctly. When I print a test page I get patchy black, streaky cyan, no magenta, and almost no yellow. I have done all the maintenance tasks I can from the director menu and no improvement. Am I correct to assume the jets are clogged. I have almost no experience w/ printer repair. I do not know how to remove the jets or clean them. But, this promises to be a great machine if I can get it working. Any advice? Thanks much.
Use isopropyl alcohol and gently rub it with a kim wipe. Do not use any type of cloth that has lint or anything like that. That could casue more clogging or damage the print head. Also, if you do not use it for a long period of time, remove the cartridge and place it on a damp cloth or sponge with the print head facing up and place it in a sealed container. It will keep the moisture in and casuing the cartridge from drying out. Check the resepticles located underneath the cartrdige in the home psition. Sometimes that will be clogged and not the cartridge.
Posted on Nov 09, 2008
    Sniper:
  • 58 Answers
On this specific model there are ink cartridge tanks and separate printheads. The printheads are located below the ink tanks. Check the user's manual for access to them. You can clean them with a paper towel like the first post suggested. If that doesn't work, replacement printheads are around $40 each and you might want to consider another machine...
Posted on Jul 06, 2007
    Novelist:
    Champion:
  • 254 Answers
This fellow is on track. I've used rubbing alcohol or some electronic contact cleaners to do essentially the same thing. Whatever will dissolve the dried ink without damagning anything else.
    Problem Solver:
  • 6 Answers
Hi, ink cartridge nozzles (jets)dry out and clog even if the cartridge is full of ink. This happens especially if you don't print often or haven't replaced the cartridge in a long time or if the "new" cartridge sat on some shelf for a long time. You can try a wet paper towel on the bottom of the cartridge where the ink comes out. Hold it there for at least a minute, then put the cartridge back in the printer and try to print. Have some hand cleaner ready-your fingers will get a little ink on them. Even if it only partially prints, then you know the problem is that the cartridge nozzles are clogged. Good luck..
SOURCE:
Won't start due to ethanol
Were the carb bowls drained before storage? Even with stabilizer the fuel can gum up and clog the tiny carb passages and jets so a carb breakdown and cleaning may be in order. There are plenty of how to's online that can walk you through the process so you won't have to pay someone to do it.
Jan 26, 2013 | Yamaha Motorcycles
HP Office Jet 630 will not print
please check whether the data cable rx232 which is used to connect the printer to pc is fine. try someone else's cable(e.g friend) and check whether it is able to print .re install the software that is provided along with the printer in the form og cd or dvd. hope your problem will be tackled then
May 25, 2009 | Office Equipment & Supplies
Double printing on single jobs.
You have software setting problem Check and double check your print dialogue box
Apr 21, 2009 | HP LaserJet 4350 Printer
Won't print black at all
Sounds like the JEt for the Black might have clogged or the print head has malfunctioned.
Feb 11, 2009 | Epson C64 InkJet Printer
Left cartiridge not printing
i've got the same problem. any solutions yet????
May 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
219 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
