Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Chewing up Chain Drive
On my LiftMaster 41A2817 Chain Drive
Garage Door stopped opeining I rordered and replaced the Gear Kit which had been ground up and stopped working (much white plasic dust)
When I installed the rplacement it lasted two months and it too had been ground up and stopped working (much white plasic dust)\
I have ordered anothe Gear Kit What is cuasing these to get chewed up?
  • samuel_truji Jan 23, 2009
    This is worthless I will go to the dealer.
    Seems like a ploy to sell advise, in bad economic times one should be offering to support one's product not sell a service.
    I feel like wjhen I came to you for assisance with your brand I got some set FAQs and an offer to sell a service.
    Offer solutioons at a cost may save the corporation some costs, however reduced satisfaction with your product will cost you customers.
  • 118 Answers
There is most likely a problem with the balance of the door. Release the door from the opener by pulling the red handle and lift the door manually. You should not have to apply more than 20lbs to lift it. When the door is at each hinge point and all the way up, it should stay by itsself. If it does not, the springs need to be adjusted or you will continue to replace gears.
Posted on Jan 27, 2009
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
How much is gear kit for 1/2 #41A2817?
Gear kits can be purchased for chain drive machines from any of these 3 brand names ...Liftmaster/sears craftsman /chamberlain / All 3 of these brand names are manufactured by Liftmaster the worlds largest maker of garage door openers and related parts ! You can purchase a gear kit on ebay for around $30 or less depending on the seller ! If you go to garage door parts sites it will be slightly higher so your best bet is EBAY , The gear kit only requires the main gear and sprocket housing that attaches with 3 screws , just remember after the gear is installed that you run the motor co that the trolley starts in the door down position otherwise you risk having the trolley smack into the opener , this is crucial for any travel adjustments that are made later! Hope this helps you ,sincerely Glenn
Feb 04, 2015 | liftmaster Garage Door 1/2 Hp
I have a Craftsman garage door opener (model 139.53637SRT - 1/2 HP) that stopped working. It sounds like the motor runs, but the chain and trolley do not move at all
The gears need to be replaced. You need
Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit available on amazon for around 20 bucks
Jan 16, 2011 | Sport & Outdoor - Others
Garage door does not open or close
You have a stripped drive gear. Remove the cover from the motor unit and you will find white sawdust all over. The part number for the gear kit is 41A2817 and is available at any good door opener service company. It comes with instructions.
Feb 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door stopped travel about 2/3 down, motor continued running but chain stopped moving?
Remove the cover and check your drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is stripped. The part number if 41A2817 and is available at any good door opener service company. It comes with instructions.
Feb 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor hums but door doesn't move. If I disconnect door and give chain a horizontal poke, it will move. When I reconnect door it returns to humming, without movement.
Remove the cover from the motor unit and you will find the drive gear has stripped. White sawdust all over. The part number for the gear kit is 41A2817 and it comes with instructions. It is available at any good door opener service company.
Feb 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chain drive gear broke on my mod.1265LM. Nead price, part no., and how to replace? Thanks Dave
The drive gear part number is 41A2817 and the price for the kit is around $25.00. It comes with instructions.
Dec 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't open or close door
The drive gear is stripped. Remove the cover and you can see it just in front of the motor. It is white nylon and the part number is 41A2817. Available from Sears or any good door opener service company. It will come with instructions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I need a repair guide for a LiftMaster garage door opener.
complete gear/bearing kit $30, comes with complete instructions.
Nov 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
90 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
