Question about Maytag Dryers
Drying time too long
I have a gas dg7500. My burner ignites but, I do not have a strong constant flame. The flame runs strong, then sputters (doesn't go completely out) then burns again cycling over and over. The clothes take longer than normal to dry and it seems to run forever without automatically shutting off on Regular cycle.
    Novelist:
  • 101 Answers
You are going to want to check and make sure there is proper air flow from the vent outside the house. If it feels weak then you will need to get it cleaned out. If enough air is not exiting the thermostat will shut off the flame for safety reasons. If your air flow seems to be working okay then it may be a problem with the thermostat. Let me know if you have any other questions and let me know if this was helpful. Good luck and I am glad i could help.
Posted on Jan 22, 2009
I have an old gas stove. No igniter.Lights with pilot light only. Stove top burners work fine.Oven does not ignite. The pilot lite is on.I smell no gas when I turn it on.
Pilot flame has to hit the thermocouple. If pilot is dory flame.will be weak and not reaching the thermocouple that tells the oven there is a flame and opens the burner. If the pilot is strong and no gas to burner than that thermocouple. ( 100% safely valve is worn out) replace that and you are good
Dec 30, 2017 | Kitchen Ranges
Dryer runs, can see burner is firing but heat setting seems stuck on ;Delicate cycle. Taking 3 hours to dry a load of towels.
gas coil condensors may not be working properly as they set the gas pressure needed to keep flame going hot. can check them with a multi meter however if flames stays on you may want to check the venting system first u might be surprised bad venting can slow down drying. check in machine and at exhaust to home. Again Each time you see the glow bar igniter come on it should ignite the gas burner. If you find the glow bar igniter glowing red for a short time and then fading off without any burner ignition would indicate weak solenoid coils. The coils are mounted on top of the gas valve and they both will need to be removed and replaced. In order to access the solenoid coils will require removing the lint filter, removing the two screws which was hidden by the lint filter and raising the top and removing the front panel.
Jan 28, 2015 | Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
No heat, ignitor goes on burner goes on sometimes and after short time goes out. ignitor goes back on, but no burner. what up
If the flame sensor is not returning a good signal, the gas valve is shut off as a safety measure. I surmise that in this situation, the igniter is programmed to fire for a time to flare off any accumulated gas from the initial attempt to fire up the burner.
Check for the following: adequate combustion air supply (make sure inlet vents are clear), proper exhaust venting, flame sensor properly positioned and not cracked or otherwise broken, burner holes are clean and not caked over with combustion deposits (if the flame is uneven and weak right where the flame sensor is located, it will be treated as a failed ignition).
In the worst case, the gas valve is defective and unable to detect the flame signal. It's also possible that a thermostat is sending an overheat signal, but that doesn't account for the igniter sparking a second time after the burner shuts off.
May 19, 2011 | Maytag Neptune MDG9700A Gas Dryer
Oven has small explosion igniting and going off. says tj
A few years back I helped a neighbor with this same problem in a forced air, gas fired, "horizontal" furnace in his attic.
After having him cycle the thermostat a couple dozen times while I watched through the opening in the side of the furnace, I finally figured out what was happening.
First, there were about 6 cast iron burners [about 14 inches long with two rows of gas holes along the length]. These burners were parallel to each other and oriented perpendicular to the long axis of the furnace.
The gas was fed to the ends of the burners with a pipe manifold. The standing pilot light was at the center between burners 3 and 4. Due to the spacing distance between the burners, the pilot light was too far from even burners 3 and 4, the flame could not "jump" to ignite them, or any of the other burners. The manufacturer had installed a thin sheet metal "tent" which ran from the gas entrance end of burner 1 to burner 6, and was about 2 inches above the burner, AND the pilot light.
The standing pilot was on all the time. When the gas control valve turned on, gas began to come out of all the burners at the same time. Naturally it came out of the gas supply manifold ends of all the burners.
The "tent" captured that gas coming from the burners and "filled" up to over the pilot light which ignited the gas at that point, and the flame would propagate along the tent to ignite the gas coming out of all of the burners.
In my neighbors case, the tent had somehow become dislodged so that it did not cover all of the burner ends. For those burners which it did cover [including the pilot light] it caused the burners to light properly.
For those burners who's ends were not covered, and who's gas could not be captured, they would NOT ignite simultaneously with the others.
As these burners WERE feeding gas into the combustion chamber, the gas "envelope" would spread until it reached the nearest flame ignition source, at which time the entire "bubble" of gas would ignite with a minor boom [actually a low energy explosion]. Flame would momentarily shoot out of the burner chamber opening, and from that point the furnace would operate normally until the next restart cycle.
Although there could be several causes, I suspect that the symptoms you describe are the result of DELAYED IGNITION of some or all of the main burners.
IF this is the problem, then the solution is to clean all the burners [including the burner outlet holes in the ignition ends of the burners], clean out the burner compartment, AND properly adjust the orientation of whatever system [you have to evaluate how it works from analysis of YOUR furnace] your furnace has to ensure all burners ignite as close to the same time as possible.
When operating properly, the ignition should be a smooth transition, burner by burner, from the pilot to the farthest burners. In other words. the ignition will "flow" from the pilot outward to each adjacent burner until the farthermost ends ignite last. This usually doesn't take more than one or two seconds at the most.
Unless you are an experienced handyman, and understand this analysis and instructions, I strongly suggest that you engage the services of a professional furnace technician.
Feb 13, 2009 | Imperial Commercial Cooking Equipment...
Gas dryer not heating properly, burner ignites at start up, then not again
Please provide the brand and model number of your dryer.. However.. you state that your dryer is not heating properly and yet the burner ignites.. If you have a flame after ignition and your dryer is drying slowly, I would be inclined to look at the blower and or vent for restrictions in air flow. The heat generated by the burner will not be optimized in terms of drying clothes if you do not move that air out . Any and all restrictions to normal vent flow will make the dryer less efficient and dry times will be longer. If you are bound an determined to get into the flame sensor and thermostat logic, then please provide a brand and model number..
Hope this helps...
Sep 06, 2008 | Dryers
Dryers Logo
90 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
